Old 02-08-2008, 06:02 PM   #1 (permalink)
rohitshubham's Avatar
Default dos compression
hi
one of my friend gave me san andreas and it was compressed in only 1 cd
after being installed it becam a 4 gb file
i dont know that how it was compressed .
first it was an sfx of winrar and then dos opened upand it started extracting with dos
can any body tell me how one can compress it with dos
rohitshubham is offline
Old 03-08-2008, 10:18 AM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: dos compression
uharc
google it.
dheeraj_kumar is offline
Old 04-08-2008, 01:57 PM   #3 (permalink)
but it dosent compress so much
Old 04-08-2008, 03:29 PM   #4 (permalink)
Amir.php's Avatar
Question Re: dos compression
Originally Posted by rohitshubham View Post
hi
The game You are try to install is pirated.
I was also facing this CD and also amazing how a CD can extract data upto 4 gb.
Amir.php is offline
Best Compression I have ever seen - How did they do this? qualia787 QnA (read only) 10 12-03-2008 08:00 PM
AVI compression help Samystic Software Q&A 4 28-02-2008 06:25 PM
high compression mak1012 QnA (read only) 22 24-08-2006 11:03 AM
Compression help vijaythefool QnA (read only) 21 20-02-2005 09:33 PM
vcd compression redhat_adi QnA (read only) 5 13-02-2005 05:54 PM
- by gforz
- by Piyush
