Old 01-08-2008, 11:07 PM   #1 (permalink)
Unhappy Windows XP starting problem
Hello Friends
My name is Pragna,
I am facing problem with Microsoft Windows XP, everytime the computer boots with normal booting and opens untill the desktop and stops.
Then only the windows related programs can be opened like My Pictures,My Videos,files
can be transferred from one drive to another,files can be deleted and even some of the
images can be viewed in Windows Fax Viewer.....Sometimes the whole system hangs....
But any other executable program like Mozilla Firefox,Internet Explorer,Windows Media Player,or sometimes even the webshots will not work.If any executable file is opened then a popup comes on the screen like this
"windows cannot access the specified device, path, or file. you may not have the appropriate permissions to access the items"
This popup will appear on the screen,if any executable file is opened until for almost 5 - 10
minutes(time is not exactly calculated),It gives an option of 'OK' to close this popup.
After this the computer starts to work normally with all the executable files opening up properly.
I do not know why the computer starts to act like this everytime I start my computer.
Everytime it will take too much time to open.I have recently formatted my system and this is the system configuration with some softwares i use...
AMD Athlon 64 Bit Processor 3000+ 1.8 GHz
MSI RS480M2-IL
512 MB RAM
160 GB Hard Disk
Microsoft Windows XP 5.1(With service pack 2)
Bitdefender Antivirus
Zonealarm Pro Firewall
Please do help me in solving this problem,Is there any problem with my hardware
or is there any software options that i have got to make.
Thank you
Pragna
Pragna is offline
Old 01-08-2008, 11:34 PM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Windows XP starting problem
Pragna this is a software problem. Try to boot from a XP cd & repair ur XP. Use a program like Ccleaner to remove some invalid registry keys & if possible don't use zonealarm(my opinion).
Blogging at:
Technostarry
saqib_khan is offline
Old 02-08-2008, 03:48 AM   #3 (permalink)
Krazy_About_Technology's Avatar
As far as i sense it, its an after-effect of a virus removal, viruses which change the .exe file associations and gets launched whenever an exe file is double clicked. Have you removed any kind of viruses within last few days? Or it may also be caused by ZoneAlarm firewall sometimes. In any case, try doing a repair install of Windows XP. You can do this by booting from Windows XP cdrom. Press enter on the first screen and the press f8 to accept license agreement. Then after windows searches for existing installations and prompts you to repair your current installation, choose Yes. Your windows will be repaired and no settings will be lost. In most cases when you return to your desktop, you find it exactly like you left it, sans the problems. Try it!
And yes, disable your virus protection while repairing.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 02-08-2008, 07:04 AM   #4 (permalink)
cooldip10's Avatar
Repair Windows First. Then tell us if the problem still persists..
For repairing windows : Just put in your Windows CD in Drive and restart and boot from CD. You will find it in option there
Everything is Possible
cooldip10 is offline
Old 02-08-2008, 06:32 PM   #5 (permalink)
Smile Re: Windows XP starting problem
Hello Friends,
I am very grateful for your humble replies to my problem.
I did not try for going in to Windows repair as i had recently installed my Windows XP before two days and i had cleanly installed all the software's of my choices.
As for the fact i did not knew how to repair,i did it twice and i think i did not go along with the correct procedure,therefore the repair did not take place at all.
And i followed your opinion about removing Zone Alarm Pro....and Viola !! !! My computer started to work lightning fast with starting just like that after booting.ZoneAlarm was my faithful firewall for these many days,bit i did not know it would backstab me one day.
Thanks really for your Replies and suggestions....I am a better person now and even my computer is working better.
Thanks Very Much Saqib, Krazy & Cooldip10
REQ : Could U suggest me some good firewall that i can use
Pragna
Pragna is offline
Old 03-08-2008, 12:25 AM   #6 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Okay, this is personal but I prefer Comodo Firewall over ZoneAlarm, coz it's lightning fast and very easy to use and top of it all, it is fully free for personal use !
Get it at here !
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 03-08-2008, 06:18 AM   #7 (permalink)
cooldip10's Avatar
Hey no thanks here!! We are here to help each other.
Very happy to know that your comp has started to work lightning fast..
May be there is something you can set in Zone Alarm which may increase it's speed.I am a Zone Alarm fan and I think there is a way out. My dad uses Zone Alarm Pro on his lappy (Never touched it since some break down happened and was scolded very badly). It works fine there + No start up issues also.
Try to disable the 'boot scanning' feature if there is some.
I use the free home version and am very happy with its service..
Old 03-08-2008, 06:12 PM   #8 (permalink)
Hello Krazzy & Cooldip
Thank U for your suggestion on Firewall and choosing the better option for it.
Let me say i will go with Comodo Firewall,since i do not believe in Zone Alarm again.
Thanks Again
Pragna
Pragna is offline
Old 03-08-2008, 08:15 PM   #9 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Zonealarm IS a good firewall, and one of the best. There is no need not to believe in it, since it gets the job done
I've been researching ZA as a part of my paper, and found that its core TrueVector Service, which is a rootkit, denies access to files till it scans them for virus/spyware as you specify in ZA settings. For the more technically inclined, When you open any file, the file handle is returned as 0, hence prompting the error from windows
dheeraj_kumar is offline
Old 03-08-2008, 11:01 PM   #10 (permalink)
Hello Dheeraj
Thank You for your feedback on Zone alarm
Pragna
Pragna is offline
Old 04-08-2008, 10:52 AM   #11 (permalink)
Fullbring
Zangetsu's Avatar
hey pragna...how many problems do u have winxp + nero problem + any other
Zangetsu is offline
Old 04-08-2008, 11:53 AM   #12 (permalink)
Hello Karan,
I have so many problems related to computer....it grows as the technology grows....But i have got myself a good forum,where i can discuss the problems and get answers,so that i can have a better life with my computer.
I had this Nero problem from so many days,i used to tackle with it alone....But i wanted some expert suggestions to solve it.
Thanks
Pragna
Pragna is offline
Old 04-08-2008, 01:03 PM   #13 (permalink)
Fullbring
Zangetsu's Avatar
ok...ok...just chillin.....its good dat atleast ur problem is solved...
dont ever use two antivirus or two anti-spyware together ..they always conflict with each other...
i guess u r using a bitdefender antivirus 2008 & not bitdefender total security 2008
bcoz the latter one has a firewall with it so doesn't require ne xtra firewall
every body here in this forum tackle their problem first by themselves only...
No Body is an expert....only time makes them expert..
Zangetsu is offline
Errors in starting windows Kerry Software Q&A 3 12-03-2006 07:16 PM
Stupid Pop up when starting windows ankush Software Q&A 3 31-12-2005 03:12 AM
Windows not starting up terminalbot Software Q&A 3 15-10-2005 09:04 AM
what could be the starting price of windows vista? rajas700 Software Q&A 9 12-09-2005 01:31 PM
windows xp starting error noblefriend2002 Software Q&A 6 18-08-2004 04:35 PM
- by gforz
- by Piyush
