Old 01-08-2008, 04:01 PM   #1 (permalink)
Default explorer not working while computer starts
explorer not working while computer starts.
i've to make atl+clrl+del...take taskmanager..run explorer before everything comes to normal.
snehangshu is offline
Old 01-08-2008, 08:53 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: explorer not working while computer starts
xp or vista?
scan with your av and anti-spy in safe mode.
maybe a malware infection has corrupted some settings
what happens in safe mode, pls check and let us know.
Also Run sfc /scannow
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 02-08-2008, 08:58 AM   #3 (permalink)
it is xp only.
safemode and other users are ok.
Old 02-08-2008, 10:00 PM   #4 (permalink)
anandk's Avatar
Did you Run sfc /scannow ?
Microsoft® MVP
anandk is offline
Old 03-08-2008, 12:31 AM   #5 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
I think that your explorer.exe has been removed from the Shell Key, so maybe you could try and fix that, u need to be careful coz it needs regeditting,
Try HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Shell then in that create a new d-word value and add the path to your explorer.exe, which would mainly be c:\windows\explorer.exe
Save this and now it should work probably
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 03-08-2008, 02:04 AM   #6 (permalink)
Krazy_About_Technology's Avatar
^Are you sure it should be a DWORD? I think it should be a String.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
computer starts automatically peyoush_thakur Hardware Q&A 6 22-06-2008 10:12 PM
Laptop Freezes and starts working again , sometimes .. :( Thor Hardware Q&A 3 09-04-2008 06:43 PM
System32 folder opens when computer starts vasulic Software Q&A 5 25-10-2006 09:37 PM
Computer Turned off & not Starts debiprasad_sahoo Hardware Q&A 4 24-02-2006 08:01 PM
computer(win xp) starts dialing automatically vikas_r_s Software Q&A 4 29-01-2005 07:10 AM
- by gforz
- by Piyush
