Old 26-07-2008, 08:05 PM   #1 (permalink)
Default Problem installing software.....
I have a strange problem with my PC.Whenever I try to install games or other software with large size of installers, I get a CRC or some other error and the installation aborts.
Even when an installer tries to unzip huge .cab files, the unzipping mostly fails...
I do not have any problems installing from small sized installer files..
The same CD/DVD installs fine when I try it on my friends' PCs.
I have tested my DVD writer on another PC(it worked fine) and have even changed my IDE cable but the problem persists..
Please help
xp_even is offline
Old 26-07-2008, 08:36 PM   #2 (permalink)
dreamsalive's Avatar
Default Re: Problem installing software.....
give ur system specs.
i think its due to low RAM or less processor speed. upgrading ur Ram can help.
Linux doesn't need no viruses. The users **** up the system by themselves.
dreamsalive is offline
Old 26-07-2008, 11:16 PM   #3 (permalink)
My system config is as follows:
Intel P4 3.0Ghz
Intel 946GZIS chipset
1GB DDR2 667 RAM
160GB HDD
XFX 8600GT Graphics
I use windows XP Pro SP2.
xp_even is offline
Old 26-07-2008, 11:26 PM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
copy the installation files to ur hard disk first and then try to install.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 26-07-2008, 11:31 PM   #5 (permalink)
I have tried that many times.It does not seem to work....
xp_even is offline
Old 27-07-2008, 10:47 AM   #6 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^please explain more,wt happened wen u tried to copy the installation files to ur hdd? and wts ur system specs?
Hav u tried the same problem causing DVD and DVD writer together in ur friends PC?
zyberboy is offline
Old 27-07-2008, 11:12 AM   #7 (permalink)
Copy the installation files from DVD to hard disk gives no errors...when i try to run the installer from my HDD then i get the same error....like "CRC failed for some file...or the certain ".cab" file does not match the on the DVD.Please contact your vendor."..
When I use the same DVD on my friends' system, it installs fine.I brought my friend's Sony DVD writer and it gave same problem on my system( mine is Samsung writer).It works fine on his system...
xp_even is offline
Old 28-07-2008, 06:13 PM   #8 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Download and install windows installer
Then do full system scan using updated kaspersky antivirus.
Then try to install the software frm Hard disk.
If the problem persist use another ram stick in ur system and try to install again.
zyberboy is offline
Old 28-07-2008, 06:48 PM   #9 (permalink)
Amir.php's Avatar
^No, it is not a virus problem.
seems you never run diskcleaner.
your temp folder has been full.
install ccleaner,run it and clean your system.
also defrag your all partitions.
Amir.php is offline
Old 28-07-2008, 07:35 PM   #10 (permalink)
dhanusaud's Avatar
my friend, its ram problem.
insert another stick & check the same. I too faced this problem, solved changing RAM slot.
There are a lot of problem created by RAMs but goes unnoticed.
my regards,
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 03-08-2008, 02:16 PM   #11 (permalink)
my regards,
Wow!!! Thanks....It really was RAM problem.One of my Transcend DIMMs were giving the problem..Got it replaced as it was under warranty....
xp_even is offline
Problem on Installing Antivirus Software Adam Cruge1 Software Q&A 4 10-07-2008 07:22 PM
installing software in ubuntu saumya Open Source 2 09-06-2007 08:51 PM
Installing Software in UR Acc. or profile ! ! ! ax3 Software Q&A 1 20-12-2005 12:45 PM
Installing software on Linux cybersunil Open Source 3 14-11-2005 04:21 AM
- by gforz
- by Piyush
