Old 25-07-2008, 01:33 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Unusual problem with video and sound!
Hello friends!
I recently downloaded a video(free) from the net and it is in XVID format. Whenever I try to run it in my DVD player (it supports MPEG4), it runs for a few seconds (just the introduction part) and then automatically stops. So I splitted the video using VirtualDub right from the place where the problem was. Now when I try to run it, it runs all fine but after running for a few seconds there is a kind of a pause in sound for a fraction of second and then the sound goes out of sync. If I pause the video for a few seconds and then start again, the sync is corrected but goes off again after a few second.
I am just not able to understand why is this happening. This happens only with this particular video and all the rest works fine, so obviously it cant be a problem with my DVD player.
On the first place, why is the video not running when it runs all fine in my computer and secondly, when splitted, why is it getting out of sync after a few seconds?
The video properties are as follows:
File : 699 MB (1.14 MB), duration: 1:35:18, type: AVI, 1 audio stream(s), quality: 68 %
Video : 3.92 GB, 5900 Kbps, 23.976 fps, 672*368 (16:9), XVID = XVID Mpeg-4, Supported
Audio : 75 MB, 110 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
Please help...
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 25-07-2008, 02:10 PM   #2 (permalink)
Default Re: Unusual problem with video and sound!
Pls check the video properties using media info or gspot and verify if it has qpel or gmc.Generally most players have problems playing avi files with qpel or gmc.If ur video has these properties, reencode the video with AviRecomp or AutoGK. You can also compress the video using VirtuallDub by using FastRecompress option and by manually setting xvid/divx properties so that qpel/gmc options are disabled.
Hope this helps..
sohancool is offline
Old 25-07-2008, 05:28 PM   #3 (permalink)
9437077259
go4saket's Avatar
It doesnt seem to have both qpel and gmc. I am posting the gspot result. May be it can help...
Win 7 Ultimate
go4saket is offline
7 Pin - S-Video Output... Flicker problem on TV. Also No sound in TV... jal_desai Hardware Q&A 12 16-10-2009 05:56 PM
unusual problem in pc saurabh kakkar QnA (read only) 3 05-05-2007 11:05 PM
a very unusual problem...but a khatarnaak one!! hearthacker QnA (read only) 3 24-05-2005 06:48 PM
Unusual XP problem! Help please... akash_bhavsar Software Q&A 10 24-01-2005 10:47 PM
Unusual,but interesting< problem with LINUX! Akash Verenkar Open Source 2 21-12-2004 07:44 AM
- by gforz
- by Piyush
