Old 24-07-2008, 04:53 PM   #1 (permalink)
Default Virus!!! Urgent help required
There is a virus which says not to use Mozilla and use IE instead. I have read a few solutions but none of them is working as the SAM virus says "Why do you want to open the Task Manager, everything is running fine"..
What should I do??
Always be OPTIMISTIC, even a stopped clock is rite twice a day....
Itz_Me!!! is offline
Old 24-07-2008, 06:34 PM   #2 (permalink)
Default Re: Virus!!! Urgent help required
http://www.askvg.com/solution-orkutc...ned-in-system/ might help
cool_techie_tvm is offline
Old 24-07-2008, 06:43 PM   #3 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
download n run this removal tool that i created
http://prashobms.blogspot.com/2007/1...istrators.html
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 24-07-2008, 09:16 PM   #4 (permalink)
No help
It says no threats found and its not allowing to open task manager.
It displays the same message as in my first post.
Any other tool or method??
Old 25-07-2008, 08:06 AM   #5 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Download KAV7 or KIS7 and try to destroy the virus.
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Old 25-07-2008, 10:39 AM   #6 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Originally Posted by Itz_Me!!! View Post
No help
hav u tried the tool that i created?if that didnt help
post a screen shot of the virus messages
zyberboy is offline
urgent help required.......... kuldeep bhardwaj QnA (read only) 1 10-11-2006 03:25 PM
urgent help required................?????? kuldeep bhardwaj QnA (read only) 4 25-06-2006 04:45 AM
help required urgent......... sankhyag QnA (read only) 2 15-05-2006 01:32 PM
virus updates required!!!!!??????????????????????????????? kunwar Software Q&A 1 07-09-2005 08:11 PM
VIRUS...RANDEX ZEN.......VIRUS MLORE HELP..??URGENT Writankar panja Software Q&A 9 19-09-2004 05:26 PM
- by gforz
- by Piyush
