whenever i try to download something from rapidshare it says"your ip is already downloading a file.plz wait until the downloads completes."but i'm not downloading anything.
how will i find out if any download is running in the background?
or is it that somebody else is downloading from my ip?is it possible?
clear ur cookies...disable net connection...reboot...then check the downloading
using Task-manager...
possible if ur system net is hacked...
It seems like you are using a shared IP address which means that two or more subscribers from your ISP are using the same IP.Best way to deal with the situation is to 1.download "very late" at night when very few people are downloading from rapidshare or 2.just keep on waiting and trying till they finish because only one person or IP address can download from rapidshare at a time.
there is no need for any software that hide or change ur ip address. u r using bsnl connection. u must be getting dynamic ip address every time u switch on the modem (i.e. ur ip address becomes different, every time u turn on the modem) ... enough said
