Hi,
After installing the ATI AGP card, my WINXP OS automatically detected the driver but not able to get driver for my win2k OS.
I downloaded the driver from ATI & gateway website but no use.
Pls help.......
Sharing you the system info using DirectX:
Display Devices
Card name: RAGE 128 PRO Ultra GL AGP (Microsoft Corporation)
Manufacturer: ATI Technologies Inc.
Chip type: RAGE128 PRO II, (AGP 4X/PCI)
DAC type: Internal DAC (350Mhz)
Device Key: Enum\PCI\VEN_1002&DEV_5446&SUBSYS_54461002&REV_00
Display Memory: 32.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvaa.dll
Driver Version: 6.13.0010.5019 (English)
DDI Version: 8
Driver Attributes: Final Retail
Driver Date/Size: 8/4/2004 00:56:42, 377984 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtaa.sys
Mini VDD Date: 8/3/2004 22:29:28, 327040 bytes
Device Identifier: {D7B71EE2-1706-11CF-2960-4C74A2C2CB35}
Vendor ID: 0x1002
Device ID: 0x5446
SubSys ID: 0x54461002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Thanks in advance..
him007
