Old 23-07-2008, 11:14 AM   #1 (permalink)
smile's Avatar
Angry Internet Problem?
I have youtelecom broadband connection...my problem is it always disconnects .Am connecting my internet through USB ...for ex:if am browsing for say 30- 40 min suddenly it disconnects..it was happening again and again , I scan with antivirus ...so i called youtelecom technical person so he checked and said me to put a lan card and connect the net through lan because usb gives a lot of problem as he said.
I wanted ask u people?
Is he saying true?
I have to changed USB to LAN ?
If yes then why is the problem connecting through USB?
SR
smile is offline
Old 23-07-2008, 12:26 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: Internet Problem?
he is fooling you. USB doesn't have such problems, I mean it is working fine with me since last two years.
BTW, I don't know the exact problem but you cab follow this link (may be there is a solution for you) http://answers.yahoo.com/question/in...7095236AAz3XrX
my regards,
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 23-07-2008, 02:04 PM   #3 (permalink)
smile's Avatar
Talking Re: Internet Problem?
Thank you for ur reply . Can anyone still help me ?
SR
smile is offline
Old 23-07-2008, 03:58 PM   #4 (permalink)
dhanusaud's Avatar
well smile, VG doesn't seems online right now.
anyway I have to use google for the same, see the link below. may any of these links be solution for you
http://www.google.com/search?sourcei...nects+randomly
Old 23-07-2008, 05:19 PM   #5 (permalink)
smile's Avatar
Smile Re: Internet Problem?
Thanks a lot dhanusaud ... will surely go through
SR
smile is offline
Internet Problem hayabusa_ryu Internet & WWW 5 09-12-2007 01:02 AM
internet problem aneesh kalra Internet & WWW 2 15-02-2007 09:14 PM
INTERNET problem D_Sathish Software Q&A 5 20-07-2006 05:03 PM
internet problem vikas_r_s Internet & WWW 4 22-08-2005 03:56 PM
Internet Explorer Problem! dare_dexter Software Q&A 10 03-09-2004 06:41 AM
- by gforz
- by Piyush
