Old 23-07-2008, 10:56 AM   #1 (permalink)
smile's Avatar
Angry System not booting
My system is not booting .....when i switch on am not getting display...i took out RAM and again cleaned it and inserted , again put to another slot and checked , even put a new ram and checked but its not booting....only monitor light is blinking continiously...I even check all the connections .What might be the problem?
SR
smile is offline
Old 23-07-2008, 11:43 AM   #2 (permalink)
dreamsalive's Avatar
Default Re: System not booting
there could be two chances:-
1) processor prob.-may b its extra heated up due to high temp.wat u can do is open up ur processor fan, clean it and apply paste(ask any comp. eng) on processor .keep inside of ur case clean & make sure no wires are blocking the air passages of case.its best to tie or tape them.
2)Motherboard-many chances r that ur motherboard is damaged/permanently stop working.
i had the 100% same prob. 3 yrs back & in my case the motherboard was no more!.if ur system is 5-6 yrs old there r high chances of faulty M.B.In that case u need to buy a new one to replace it.
Linux doesn't need no viruses. The users **** up the system by themselves.
dreamsalive is offline
Old 23-07-2008, 06:31 PM   #3 (permalink)
check ur mother board manual....
if the problem is with RAM, there u can c the symptoms....
can u hear the beep sou0nd??? for every pattern of the beep sound, there is some particular reason behind it.....
Try resetting the BIOS by removing the battery....instructions will be there in the manual...
sarincv is offline
Old 24-07-2008, 12:28 AM   #4 (permalink)
smile's Avatar
Unhappy Re: System not booting
I removed the CMOS battery and again put battery in........change the Ram , no beeps sounds r coming
SR
smile is offline
Old 24-07-2008, 12:34 AM   #5 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Can be the case of a Faulty PSU !
The PC is just not starting up or the prb. is that u r unable to see the display ?
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 25-07-2008, 01:24 AM   #6 (permalink)
smile's Avatar
PC is starting up fine.............but am not getting display nor beep sounds
SR
smile is offline
Old 25-07-2008, 05:08 AM   #7 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Go check the drive light if it is blinking. Are you sure that the monitor and Pc cable is working correctly? Maybe the cable is broken. You can easily buy one from and electronic store.
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
Plz Help!!!!!!!! System Not Booting!!!! george101 Hardware Q&A 1 02-06-2008 01:13 PM
frustrated ! system not booting digitizen Hardware Q&A 5 23-09-2007 05:22 PM
system booting problem sanftpup Hardware Q&A 4 22-08-2007 11:20 AM
System Display goes off while booting rajivnedungadi Hardware Q&A 3 24-11-2006 01:58 AM
Urgent...Please help.....winxp system not booting Darthvader Software Q&A 4 08-02-2005 09:20 PM
- by gforz
- by Piyush
