Old 22-07-2008, 12:21 PM   #1 (permalink)
U-ME=NOTHING
Exclamation Digit Archive Update Problem
Hi
I have installed Digit Archieve from the CD, but whenever I am trying to update it it hangs and show the following error.
"Unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immidiately.
The underlying connection was closed. The connection was closed unexpectedly."
Now if I click on continue nothing happens, and it hangs, so I need to quit. There is a button called details, when I click on that I got the folowing message:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.WebException: The underlying connection was closed: The connection was closed unexpectedly.
at System.Net.WebClient.DownloadFile(Uri address, String fileName)
at System.Net.WebClient.DownloadFile(String address, String fileName)
at Archive0._2.frmArchive.UpdateArchive()
at Archive0._2.frmArchive.btnUpdate_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Archive
Assembly Version: 0.3.0.0
Win32 Version: 0.3.0.0
CodeBase: file:///C:/Program%20Files/Digit%20Archive/Archive.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I have uninstall and reinstall the Archive from different month's cds, but it doesnot help.
So, please tell me how can I overcome this error.
bhutbhut is offline
Old 22-07-2008, 12:56 PM   #2 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
Default Re: Digit Archive Update Problem
I am also facing problem with updating digit archive.
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
adithyagenius is offline
Old 22-07-2008, 04:35 PM   #3 (permalink)
Amir.php's Avatar
I think some problem in installer.
Amir.php is offline
Old 03-08-2008, 07:42 PM   #4 (permalink)
U-ME=NOTHING
Hi
isthere any solution for this problem ?
bhutbhut is offline
Old 03-08-2008, 08:18 PM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Erm, I dont buy Digit so I cant really debug the provided app. It is not a problem in the installer, as I see other parts of the app start working. Looking at the exceptions list, either you arent connected to net, or there is a firewall blocking access. Those are two things you can check - connect to net, and add it to the exceptions list of your firewall.
dheeraj_kumar is offline
Old 04-08-2008, 12:26 PM   #6 (permalink)
U-ME=NOTHING
Hi Dheeraj
Thank you for your suggestion, but I have already added it to my firewall exception list, I think it has some problem with the software itself.
bhutbhut is offline
Old 04-08-2008, 05:24 PM   #7 (permalink)
Maybe. You should wait for other members' replies who buy digit.
Old 04-08-2008, 07:42 PM   #8 (permalink)
In a New flavour
Most Wanted's Avatar
^^Shayad mera hi wait kar rahe ho?
email this problem to-
sos@jasubhai.com
Life Grows Best, When Deciplined
Most Wanted is offline
Old 04-08-2008, 08:12 PM   #9 (permalink)
kumarmohit's Avatar
I think they have given up on the archive. The last update to the beta was in June or July 2006. Since then the program code has not been updated!
kumarmohit is offline
Old 06-08-2008, 01:16 PM   #10 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
is adobe reader 9 given in any digit cd\dvd ?
can any1 check plz ??
... W H O T ...
ax3 is offline
Old 12-08-2008, 06:49 PM   #11 (permalink)
the problem remains.....
We are even now installling a software whose version is "2006, beta" !!
zonealarm and net speed is not the problem as I feel.
gopalkalna is offline
Old 15-08-2008, 08:39 AM   #12 (permalink)
Gaurav's Avatar
I am having the same problem, the digit archive software has stopped updating some 4 months back. now whenever I update it gives me an error exactly as stated by 'bhutbhut'.
It was a nice software . Hope digit will come back with some solution to it.
Gaurav is offline
digit software archive problem kanu2k7 Software Q&A 1 22-07-2008 03:16 PM
digit archive software problem alagappan Software Q&A 2 13-04-2007 10:50 PM
Update Digit cd archive ! ! ! ax3 QnA (read only) 5 08-05-2006 08:27 PM
digit cd/dvd archive niranjan_mcarenyold QnA (read only) 11 09-09-2005 07:09 PM
- by gforz
- by Piyush
