Old 22-07-2008, 12:11 PM   #1 (permalink)
In a New flavour
Most Wanted's Avatar
Unhappy Urgent help virus!
Every time while i try to open any folder this error occured:
ATTENTION, MM!
Some dangerous trojan horses detect in hour system.
Some detect dangerous trojan horses in hour system.
Microsoft windows xp file corrupted.
This may lead to the destruction of important files in C:/Windows.
This may lead to the destruction of important files in C: / Windows.
Download protection software now!
Download Software Protection Now!
Click ok to download the antspyware (recommended)
Sim Não
Yes No
And it tries to carry out me on this site:
http://ie-antivirus.com/download.php.
Please urgent help me.
I have uses all antivirus and antispywares, ccleaner but no help
Life Grows Best, When Deciplined
Most Wanted is offline
Old 22-07-2008, 02:17 PM   #2 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Default Re: Urgent help virus!
Follow the instructions given here:
http://www.removeonline.com/remove-a...n-your-system/
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 22-07-2008, 02:21 PM   #3 (permalink)
God of Mistakes...
Garbage's Avatar
Use Spybot and search for spywares or adwares !
Your system is seriously infected !
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 22-07-2008, 04:09 PM   #4 (permalink)
Amir.php's Avatar
Also you can try SmitFraudFix. Download it from here:
http://siri.geekstogo.com/
After download boot into safe mode and run it and follow the instructions.
Amir.php is offline
Old 22-07-2008, 10:57 PM   #5 (permalink)
In a New flavour
Thanks buddy for your suggestions, My problem is not solved yet.
@Kl@w-24 i tried all according to link but not help.
@Amir.php i download you say but when i tries to run it nothing happens.
Now other suggestions or format?
Old 23-07-2008, 05:15 AM   #6 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
The message itself is from a virus
I was once trying to design a similar thing to replace logonui.exe and display a message asking weather you want to continue or restart to recover from an error... both restarted the system
That project was halted because me and my friend didn't find enough time.
But yours looks more nasty.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 23-07-2008, 09:04 AM   #7 (permalink)
Amir.php's Avatar
New Idea:
These types of problem many times occured when you are trying to install unsecured third party software.
I have faced slightly different problem in past, in which it also tries to move on some site while openning ie and i solve it by as:
1. goto c:\windows\system32
2. right click on an empty space and arrange icons by > Modified
[this will arrange all newly created file in bottom.]
3. now in the bottom locate for any newlly created .dll file from yesterday to today.
4. delete it. and restart.
Do it all in safe mode.
Sometimes some adwares places .dll file in system32. this causes problem may occurred.
Amir.php is offline
Old 23-07-2008, 06:36 PM   #8 (permalink)
scan ur system with kaspersky or bit defender......
sarincv is offline
Old 25-07-2008, 05:20 AM   #9 (permalink)
Boom Boom Boom
cooldudie3's Avatar
Post a HijackThis Log. That will show quite a lot.
Download HijackThis!
Install but do not run the program
Click here to download the Download Deckard's System Scanner. I found this in Aumha forums. double click the program just downloaded. There should be a scan. When the scan is finished, there should be two notepad files open, Main.txt and Extra.txt. Go to Format and uncheck word wrap if it is checked. Then do a copy/paste and paste the log onto a post.
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
dedly virus..plz help...**urgent** Abhishek Dwivedi Software Q&A 13 10-12-2007 07:41 AM
virus problem very urgent raysoni_r Software Q&A 4 22-01-2007 08:25 PM
[urgent] Infected by a virus...please help! ApoCalypse Software Q&A 2 31-03-2006 12:50 AM
Urgent Help...virus...? gdatuk Mobiles and Tablets 2 10-09-2005 11:44 PM
VIRUS...RANDEX ZEN.......VIRUS MLORE HELP..??URGENT Writankar panja Software Q&A 9 19-09-2004 05:26 PM
- by gforz
- by Piyush
