Old 22-07-2008, 12:34 AM   #1 (permalink)
Always friendly as DIGIT
binilmb's Avatar
Exclamation help please
From the last two days I am facing different type of problem. i.e when I am downloading a file from the internet using ie explorer or firefox, the file saving window appears but the file name column automatically fills with the letter "j".
not one letter, it is like we are pressing that key continuously. i.e "jjjjjjjjjjjjjjj". But when we hit the backspace key that is stopped
what is this prblm ? is it any bugs or viruses ?
binilmb is offline
Old 22-07-2008, 12:54 AM   #2 (permalink)
Tech'ing life seriously!!
sude's Avatar
Default Re: help please
cant say surely... mite be keyboard problem..
how many years is ur keyboard old and is of which brand?? please post...
lastly as u are suspecting any malware in ur system.. i would suggest post a HijackThis LOG in this thread, we will scrutinize and let u know..
download Hijackthis from www.filehippo.com/download_hijackthis
SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 22-07-2008, 05:18 AM   #3 (permalink)
jal_desai's Avatar
make sure ur 'j' letter key is properly working .. i mean going in and out... i think it is getting sticked from inside... try to clean ur keyboard a bit... see if the problem gets rectified.
TechExplorer.in
jal_desai is offline
Old 22-07-2008, 06:57 AM   #4 (permalink)
Amir.php's Avatar
Arrow Re: help please
May be virus/malware problem.
U are saying this problem is occurred only when the file saving window appears.
Tell us if any other time this type of problem occurred!
Update your antivirus and antispywares and do a through scan.
Amir.php is offline
Old 24-07-2008, 03:28 AM   #5 (permalink)
binilmb's Avatar
Cool Re: help please
while saving am not pressing any key. Anyway there is no prblm at this time. Thanks for ur reply
Hi guys, pleas tell me how to recover a system using norton ghost ?
am installed NortonGhost 2003 and backup my all programs and OS. But unfortunately windows is not booting up. so what can i do ?
binilmb is offline
Old 24-07-2008, 07:59 AM   #6 (permalink)
Amir.php's Avatar
Lightbulb Re: help please
found a best tutorial here:
http://www.backuphowto.info/how-to-t...orton-ghost-12
Amir.php is offline
Old 09-08-2008, 02:17 AM   #7 (permalink)
binilmb's Avatar
Hi Amir,
Thankz for ur reply. I am asking you how to restore a backup file (created with norton gost) to a non working system ?
That is, I am backup all the data in my C:\ and D:\ drives. C:\ contains my OS i.e XP and D:\ contains my other programs. my problem is that windows is not booting due to some virus crash. Is any way to restore my system to that working mode.
binilmb is offline
- by gforz
- by Piyush
