Old 21-07-2008, 06:42 PM   #1 (permalink)
Livin my Dreams
kanu2k7's Avatar
Question digit software archive problem
I have this software now for a long time and it has been useful to me but now there is some problem coming I cannot update it. Please help the error is shown below:
The details are as follows:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.WebException: The underlying connection was closed: The connection was closed unexpectedly.
at System.Net.WebClient.DownloadFile(Uri address, String fileName)
at System.Net.WebClient.DownloadFile(String address, String fileName)
at Archive0._2.frmArchive.UpdateArchive()
at Archive0._2.frmArchive.btnUpdate_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Archive
Assembly Version: 0.3.0.0
Win32 Version: 0.3.0.0
CodeBase: file:///F:/Program%20Files/DigitArchive/Archive.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Please Help What to do now???????
kanu2k7 is offline
Old 22-07-2008, 03:16 PM   #2 (permalink)
Tech'ing life seriously!!
sude's Avatar
Default Re: digit software archive problem
WELL even i m facing the same prob..
can't update the archive...
SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Digit Archive software ! ! ! ax3 Software Q&A 9 05-06-2007 01:30 AM
digit archive software problem alagappan Software Q&A 2 13-04-2007 10:50 PM
Update Digit cd archive ! ! ! ax3 QnA (read only) 5 08-05-2006 08:27 PM
digit cd/dvd archive niranjan_mcarenyold QnA (read only) 11 09-09-2005 07:09 PM
