Old 21-07-2008, 01:24 PM   #1 (permalink)
k_blues24's Avatar
Default help needed in this issue...
Hi frnds,
I am using Sony's CD-RW CRX320E combo Drive but from the last few months
It Can't read the DVD video files or it can't read some DVDs also. But It reads Digit/Chip DVDs perfectly.
I had tried to search for the firmware updates on net but i can't get it. Anybody please tell me wats wrong with my drive. Pls give suggestions.
Thanks
S
k_blues24 is offline
Old 23-07-2008, 02:32 PM   #2 (permalink)
dreamsalive's Avatar
Default Re: help needed in this issue...
yep,same prob. with mine benq combo & i had to buy a new one (lg).i dont thnk there is any solution to this then replacement......try cleaning the lens & just hope it'll work.
Linux doesn't need no viruses. The users **** up the system by themselves.
dreamsalive is offline
RAM Issue? stylecraze QnA (read only) 4 30-05-2008 11:50 PM
Help needed. Things needed to connect SATA HDD to... prashantmaxsteel Hardware Q&A 3 21-11-2007 12:26 PM
HELP NEEDED FOR MONITOR ISSUE mandar5 QnA (read only) 2 30-09-2005 08:57 AM
- by bhaskar
- by Soumik
