| Forum |
#1 (permalink) |
mekalodu
is it possible to have two OS running on one system at the same time ?? i v heard it is possible i dunno exactly how. i want linux/Sun Solaris and windows XP running at the same time on my system. my system specs ms windows xp sp2 intel pentium D cpu 2.66 Ghz 512MB RAM(mite need 1gb i think)
mekalodu |
#2 (permalink) |
Bond, Desi Bond!
1) Microsoft Virtual Machine
2) VMWare workstation 3) Sun VirtualBox
My first blogspace: http://desiibond.blogspot.com Last edited by desiibond; 20-07-2008 at 08:28 PM. |
#4 (permalink) |
mekalodu
![]() plz look the abv config of my machine and let me know if an 2GB/4GB upgrade is possible and if possible also let me know the cost. thank you
mekalodu |
#6 (permalink) |
The Smaller Bang
you will need minimum 1.5GB of ram. Solaris recommended to have 1GB atleast. And Windows XP needs 512MB.
http://TheSmallerBang.wordpress.com eMachines E725 - T4400 2.2GHz, 1GB, 160GB Nokia 5130XM * T-Sonic 610 2GB Nokia 2323C * Samsung Galaxy Y Apple iPad 2 16GB WiFi |
#8 (permalink) |
BSD init pwns System V
go for atleast 2-3 GB RAM.. windows xp 32-bit can't detect more than 3.2 GB RAM.. and try virtual box.. its the best
My blog :- www.openenclave.wordpress.com |
#9 (permalink) |
Not really. 266 MHz is the basic clock frequency. DDR (1 or 2) effectively operates at twice the clock freq., so your memory is usually called DDR2 533 MHz.
You can buy and install 667 or 800 DDR2 RAMs, but they will run only at 533 speed for two reasons : Your motherboard supports only up to 533 MHz type memory. Even if your mobo supported faster memory, it will still run at the speed of the slowest memory installed unless you remove your present 512MB/533 RAM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| problem running utorrent and browsing internet at same time | hskpunjabi | Software Q&A | 1 | 12-07-2008 07:27 AM |
| System running below its Potential??? | krinish | Hardware Q&A | 5 | 27-02-2008 01:08 PM |
| Time is running out | Voldy | Random News | 1 | 31-12-2007 08:18 PM |
| Firefox not running on system | koolbluez | Software Q&A | 2 | 17-05-2007 02:54 PM |
| My new system is running slower compared to my previous system! | instinct | Hardware Q&A | 12 | 13-10-2006 12:57 AM |
