Old 19-07-2008, 07:46 AM   #1 (permalink)
Thumbs up virtualdub problem
hi friends............
i use virtual dub first time to cut a clip of 100MB from a movie.when i click on "save as avi" it save the clip at size of 1GB . even the whole movie size is 700MB.
i just opened movie---selected the clip---then clicked on save
so is there any configurations and options that i have to change to get actual size.
thanks for any advice
__________________________________________________ ______
make free calls all over the world....
its true worked for me
http://blogs.bharatstudent.com/sytb
http://www.bharatstudent.com/blogs/v...2313&mode=blog
smslca is offline
Old 19-07-2008, 08:23 AM   #2 (permalink)
Amir.php's Avatar
Default Re: virtualdub problem
^^Check this simple tutorial and then Try to do same cut again, and write what happened.
http://www.divx-digest.com/articles/cutavi.html
Amir.php is offline
Virtualdub tasks ratedrsuperstar QnA (read only) 1 22-08-2007 12:36 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
virtualdub settings CyCo Software Q&A 1 28-12-2005 05:37 PM
Using VirtualDub to Capture Video from Pinnacle PCTV Card dabster Software Q&A 1 21-11-2005 08:06 PM
VirtualDUB blues ? Please help Tech&ME QnA (read only) 10 22-05-2005 01:34 PM
