Old 18-07-2008, 01:13 PM   #1 (permalink)
saipradeepg's Avatar
Default 5.1 Sound system
Hi Guys,
I'm able to play movies perfectly but when i play mp3's i'm getting decent quality but not on all the speakers...I dont know why..Please help me...
I have creative soundblaster live 24 bit and creative inspire 5200 speaker system.
all the speakers are perfectly fine....
when i play mp3's, only 2 speakers are getting the output...
saipradeepg is offline
Old 19-07-2008, 08:20 PM   #2 (permalink)
Default Re: 5.1 Sound system
it is evident that u have not configured the connection from the sound card to the speakers properly...or have not made proper settings on ur Soundblaster Software.
sound cards essentially have 3 stereo output(blue,green,red)...depending on the make of ur speaker(i m not aware about the inputs of 5200).....u need to make proper connection.....check the user manual for assistance.
If ur sure that u have made the connections properly then check the setting in ur creative software that came with ur card.
rohitkorde is offline
Old 19-07-2008, 08:24 PM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Also check whether Windows is set to recognize the 5.1 system. Go to Control Panel->Sounds & Audio Devices and under Speaker Settings, click Advanced. Now select the setup as 5.1 surround sound speakers.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'.
www.abhi247.com | The Photohblog
Kl@w-24 is online now
Old 20-07-2008, 12:38 PM   #4 (permalink)
iamphoenix
b.paarthasarathy's Avatar
Wink Re: 5.1 Sound system
i've also got the same problem when i bought the pc ....
i will tell u the steps how i solved the problems ....
there will be three modes in ur 5.1 ..... (as in my galaxy 5.1 speaker)
1. 5.1 or ac3 or somthing like that
2. aux
3. pc
but needn't be the same in case ur speaker....
change the mode to "pc" provided that u connected ur wires frm ur pc to the "pc" section at the back of ur woofer or amp .... now all speakers will work.......
but remember this will work only for ur mp3's .... but if u wanna play any 5.1 encoded dvd movies means again switch back to 5.1 mode.....
~~Treat your password like your toothbrush. Don't let anybody else use it, and get a new one every 3 months.~~ []
b.paarthasarathy is offline
Old 21-07-2008, 10:27 AM   #5 (permalink)
ajaybc's Avatar
I think you need to turn on speaker fill.As mp3s are stereo and turning on speaker fill creates a virtual surround environment.
Available for freelance web development jobs.
You can view my portfolio here.
Ajay Balachandran
Please contact via PM
ajaybc is offline
Old 21-07-2008, 11:27 AM   #6 (permalink)
Gracias Senor
dreams's Avatar
I visited reliance digital store in ambience mall last week..I saw altec lansing 5.1 speaker set for 3990/-
Is it worth buying this 5.1 altec for that price. Not sure whether it is incl of taxes or exclusive of taxes.
Is reliance digital shop good???
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 21-07-2008, 01:20 PM   #7 (permalink)
ajaybc's Avatar
It must be Altec Lansing VS3251.I bought it one month ago at Cochin for Rs.3750.
Ajay Balachandran
ajaybc is offline
Old 21-07-2008, 01:39 PM   #8 (permalink)
Gracias Senor
dreams's Avatar
^^ is it good??? browsed other similar posts and got Logitech was good in this category???
dreams is offline
Old 18-08-2008, 04:22 PM   #9 (permalink)
Nikhilcgnr's Avatar
Originally Posted by saipradeepg View Post
Hi Guys,
turn on cmss 3d in ur creative control panel
Nikhilcgnr is offline
Good sound System imported_tabrez Reviews 27 20-08-2008 09:00 PM
Help me in Buying 5.1 sound system hayabusa_ryu QnA (read only) 29 08-01-2008 09:20 AM
help needed for system sound rajeev1981 Hardware Q&A 2 23-08-2006 03:42 AM
NO SOUND in my system !!!! ashu888ashu888 QnA (read only) 16 19-03-2005 02:10 PM
