| Forum |
#1 (permalink) |
iam using 256kbps unlimited package bsnl router. normally my downlod speed will reach upto 38kbps in utorrent.i saw utorrent tweak on internet. after doing all said in it and applying EVID4226patch my download speed is not increasing 30kbps. but when i download exe and other files using IDM v12 download speed reaches to max of 40kbps before and now. then i uninstall the patch and reset all the tweaks i done but speed is still in 28,29kbps only. how can i regain my speed back.. thanks for any replies.... |
#6 (permalink) |
Make sure the ports are accepting the incoming TCP connections... To check this,
1) open utorrent. 2) goto Options >> Speed Guide 3) Click the Test if port is forwarded properly button 4) Ur default browser will open and will show u the result. 5) If the answer is "OK" , goto step 8, else goto step 6. 6) Put a random number (>10000) in the text box lying beside the Test if port is forwarded properly button. [I use 61281 and it works extremely good for me. I get speeds near 120 KBps] 7) Click Use selected settings button 8 ) Restart uTorrent. Hope this works... and never ever apply patches.. it screws up the whole thing... if some website suggest u some manual tricks then do it...because in this case YOU KNOW where u r making changes and can revert back if something goes wrong...
TechExplorer.in |
#7 (permalink) |
thanks jai....
i have changed the port.now i get max of 34kbps.but its not stabilising at 30's within secs it getting down to 28 around could u also give me a solution to stabilze it thanks for ur solution |
#8 (permalink) |
dá ûnrêäl Kiñg
^do this
Set the value 15 or 20 for "Maximum no of connected peers per torrents" in preference tab , also reduce the total upload slots to less than 10 then it will stabilize
My Stomach pains http://tinyurl.com/32jj4m |
#9 (permalink) |
Core i7 (nehalem) Owner
It also depends on the peers that u are connected to, and yes its completely different funda for d/loads via d/load managers like FDM or IDM..
And yes, u are getting really good speeds...so no problem with that..but if u are trying to say that u shud get a CONSTANT and stable speed of 30KBps for a torrent, then u are wrong my frend.. coz the speed actually depends on the seeders that u are connected to and how well they (the seeders) upload their data/files/parts.... I too hv a MTNL Night UL 256 kbps conn.. and i get a speed of 24-25KBps for a really good seeded torrent.. _______________________ Cheers n e-peace....
Core i7-920 MSi X58 Pro-E Corsair 3x1GB Tagan BZ1100 GTX280 SSC+MSi N580GTX TWIN FROZR II/OC WD 1TB 22" Samsung 2233SW APC SUA1500i UPS Core i7:thinkdigit.com/forum/showthread.php?t=110397 |
#10 (permalink) |
dá ûnrêäl Kiñg
For 256kbps connection 25KBps is poor speed,try reducing the total peers connected per torrent as i earlier said
#11 (permalink) | |
Legen-wait for it-dary!
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
#12 (permalink) |
yup, i too think so... ![]() Btw, zyber, is that ur tried adn tested method of reducing no. of peers, wont that reduce the no, of seeders as well and in turn reduce the d/load speed ?
#13 (permalink) |
the best thing is to use a random port and test which port gives max d/w speed
and one more thing enable encryption coz BSNL is often accused to throttle p2p speeds.. BTW i am getting 200-250 kbps on a 2 mbps home 500 plan
☼ onlyfreewares.info ► Onlyfreewares...Nothing Else !! ☼ regtweak.info ► Windows Registry hacks and tricks ☼ blog.aditech.info ► There is something for everyone |
#15 (permalink) | |
dá ûnrêäl Kiñg
yes it will reduce the no of seeders,but for 256kbps connection u dont need many seeders,reducing the no of connected peers per torrent reduces network overhead caused by all these connection,before doing this settings my speed varied between 24~32kBps(peers comes & goes) even for well seeded torrent,now its constant 30KBps,but u shud find ur optimum settings , mine is 15
#17 (permalink) | ||
Yaa, imp point asked... _______________ Cheers n e-peace...
#19 (permalink) |
Wat foes that mean in simpler terms ?? and how to do it ? : (
#20 (permalink) |
dá ûnrêäl Kiñg
^Right click on the torrent and the set the upload limit(6~7 kbps for 256kbps connection)
In preference >Bitorrent
#21 (permalink) |
THanx for this..
will try that and let u knw here... btw, u get 30KBps on a 256 kbps conn ?? is it ? and from pvt. or public tracker ?> its really good then..
#23 (permalink) |
^^ awesome,
will giv it a try.. ------------------------------ i hv these values: Global max no, of connections=250 MAx no, of connected peers per torrent=90 no, of upload slots per torrent=4 -------------------------------------------- So, i guess i'll hv to change jus the no of peers, ??
Core i7-920 MSi X58 Pro-E Corsair 3x1GB Tagan BZ1100 GTX280 SSC+MSi N580GTX TWIN FROZR II/OC WD 1TB 22" Samsung 2233SW APC SUA1500i UPS Core i7:thinkdigit.com/forum/showthread.php?t=110397 Last edited by ashu888ashu888; 24-07-2008 at 01:24 PM. Reason: Automerged Doublepost |
#24 (permalink) |
hi manusag...........
u asked me how can i get that much speed. i dont know the answer but i can show u picture. tell me why i got that speed. i just happens sometimes only. this situation comes maximum when my system hangs out for a second. is there any reason? im willing to know im attaching the picture torrent speed.pdf of the speed bar shown in utorrent verify it.... hey why are my .jpg format pictures uploaded not displaying any picture when opened. another two threads got no replies because of this reason please anyone can help me Last edited by smslca; 24-07-2008 at 05:08 PM. |
#25 (permalink) |
dá ûnrêäl Kiñg
@ashu888ashu888
Try these settings Global max no of connections 200 Max no of connected peers per torrent 50 no of upload slots per torrent 2 if the speed is not stable reduce "no of connected peers per torrent" @smslca wtf..............1770 torrents!!!
My Stomach pains http://tinyurl.com/32jj4m Last edited by zyberboy; 25-07-2008 at 12:53 AM. |
#26 (permalink) |
hi guys ...i have a ques related to this topic so i am posting here instead of creating another thread.
I am on a Night Unlimited(9PM-9AM) 2Mbps connection, but my torrent speed never goes past 205 KBps .... wats the setting u ppl suggest? My present settings are : Global max no of connections 750 Max no of connected peers per torrent 300 no of upload slots per torrent 8.
Wats the Favourite Mathematical Function of DIGIT FORUM ???? They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!! |
#27 (permalink) |
^^ well, do u get this for all the torrents ??or any particular one ?? if u get it for a particular torrent, then the torrent might not be a well seeded one,
but it also depends on the speed of the uplaoder too..(u cannot d/load more than wat the uyploaders are uploading, a simple common sense But, if this is the speed taht u get for all torrents, try reducing the values of the global max no, of conn from 750 to 700 to tel, u in simple terms.. this is a numbers game adn there is no standardised values for every one..u jus hv to play witht eh values untill u get the right mix of d/load and speed yar... i hope u understand... note: a conn is a good one if u get a speed of d/load closer to the actual speed of ur plan.. ------------------ Cheers n e-peace....
#28 (permalink) |
thnx for ur reply.
This is the max speed for all downloads even if there are 3-4 torrents with a large no of seeders .. i will try to tweak the settings to get the right combination. Hope it works. Thnx again buddy.
#29 (permalink) |
I hope u are not d/loading several torrents in aprallel ?? i mean simultaneously..??
also,for a 2mbps conn a 700MB file shud be d/loaded in 15-20mins i guess...
#30 (permalink) |
no buddy ...
2Mbps = 256 KBPS= 4sec per MB 700 * 4= 2800 sec/60 = 46 min 40 secs only when u get full 256 KBPS typically i get around 200KBPS , so 12 mb per minute or 720 mb per hour.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Utorrent speed help!! | 047 | Software Q&A | 6 | 10-08-2008 11:48 AM |
| Download using utorrent...pls help | sesi5674u | Internet & WWW | 7 | 16-08-2007 05:31 PM |
| utorrent prob, upload speed is higher than download speed | daemon | Internet & WWW | 2 | 17-07-2007 03:05 PM |
| ADSL Speed for Utorrent | idea | Hardware Q&A | 2 | 08-07-2007 05:05 PM |
| utorrent can't download!! | *GandaBerunda* | Software Q&A | 1 | 26-05-2007 05:56 PM |
