Old 03-08-2008, 10:18 AM   #31 (permalink)
Default Re: utorrent download speed problem
is your router port forwarded??
btw...which router u have ??
go to portforward.com and get the method to do so....
I port forwarded my router and get good speeds....most of the time..its above 150Kbps
I have BSNL 500 plan.
PS: BSNL does not provide good speeds on unlimited plan
Regards
imageek is offline
Old 04-08-2008, 10:40 AM   #32 (permalink)
bhunnu16's Avatar
If u are running 3 torrents simultaneously try limiting the download speeds of each equally.Like if u get a speed of 205 Kbps, keep the max. download speed of each torrent to 70 kbps. Like this ur bandwidth will be fully utilized and one torrent will not be eating the b/w of other.
PS: Waise which connection u using? BSNL and MTNL don't hv a 2mbps Unlimited plan at cheap rates and also the night hours are less.
|)3$I/\/\iT/\/Ic|<
bhunnu16 is offline
Old 04-08-2008, 03:19 PM   #33 (permalink)
harryneopotter's Avatar
@ imageek and Bhunnu
I Am using TATA (VSNL) broadband and have Broadcom Router or ADSL Modem (watever u call them) and havent used "port forwarding" till now.
My prob is ...whether its 1 torrent or 7 torrents, the speed hovers around 195-200 mark (combined speed of all the torrents in case of more than one torrent). I dont limit the speed of individual torrents as some torrents dnt have good speeds (like 7-8k to 45k) so i let them adjust the bandwidth automatically between them.
I have TATA Connection and the plan details are as follows :
Price of pack : 1922 Rs (inclusive of all taxes)
Validity : 3 months
Free Usage : 86 hrs (for 3 months) i.e. approx 1 hour daily.
Night Unlimited : 9 PM to 9 AM daily.
So its fine for me as usually i use net after 9 PM, and 12 hrs daily for download @ 2 Mbps is sufficient for me.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 22-08-2008, 12:48 PM   #34 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
yes, u are doin wrong.... btw wats the no of peers tat u get for tat torrent ??? is it well seeded ??? and wat are ur values for connections ?? plz list them down here..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 24-08-2008, 04:50 PM   #35 (permalink)
Elevating Humanity
The Conqueror's Avatar
1. Try to Download From Private Trackers.
2. Check If your torrent has large number of seeders and less number of leechers. Most of the time even though you may have large amount of seeders but the seeders often limit their upload speed to 1KB/s so it is a better Idea to check if the seeders are seeding with high speed
3. Try to Download from other torrents
Regards,
The Conqueror
The Conqueror is offline
Old 25-08-2008, 11:33 AM   #36 (permalink)
Originally Posted by orfeas7studio View Post
Well,after lots and lots of different ports i managed to reach a 150kbps download speed and now it has dropped down to 25-30,probably cause there aren't many seeders! 30 peers! (its a 34gb torrent("Friends")and with that speed......)
Thanx anyway for the help!!!
Appreciate that!
tats the best u can get for a 34GB torrent buddy...
well, its not coz of less no. of peers tats causing the proble, the thing is, since its a large file opf 34 gb, no particular seeder wud be remaining uploading at a constant rate as a result of wich u get so fluctuating speeds...
Tip: if that torrent file was divided into several multiple parts, try d/loadoing 2Gb at one go, i.e only after the 2GB out of the 34GB hv been d/loaded, then go in for the next 2GB and so on...
by doint his, u'll hv less number of files to be d/loaded at one time as a result of wich u will definately get good speeds..
I myself hv d/loaded at a whooping rate of 225 kbps on my 256 kbps conn. with jus 11 peers, but in my case i had jus selected part-by-part file d/load ... (as explained above)
many ppl will say different things, but this is the main reason y u are getting so poor speeds..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 25-08-2008, 12:53 PM   #37 (permalink)
Elevating Humanity
You mean 225KB/s or 225kbps?
Regards,
The Conqueror
Old 25-08-2008, 05:08 PM   #38 (permalink)
Lets Do It!
amrawtanshx's Avatar
Obviously 256kbps ....
How can it be 256kBps ....
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 25-08-2008, 05:22 PM   #39 (permalink)
I have Airtel 384 kbits/s UL plan,
But for torrents I never get speeds above 40KBps(always 30-40KBps) and even if it crosses 40KBps it drops down immediately to below 40KBps,
I'm using Windows XP SP3,uTorrent 1.8 and my port is properly forwarded(59393), (Beetel 220BX Router)
I haven't entered the port number in "Virtual Server" however I have entered my LAN IP Address in "DMZ Host"
However while downloading files from Rapidshare etc. I get speeds of 44-50KBps.
Xccentricity is offline
Old 25-08-2008, 06:16 PM   #40 (permalink)
Elevating Humanity
Yeah just wanted to Confirm
Regards,
The Conqueror
Old 26-08-2008, 11:50 AM   #41 (permalink)
ofcourse it is 225 kbps .... if tat was anything into capital, i wud be the king of the world
well, buddy wen u d/load a file from RS, u always get a constant speed bcoz u d/load from a server wich is transmitting (giving u file) at a constant rate where as in µTORRENT or any other torrent client for that mater, u DO NOT d/load froma server instead u d/load from users and hence its the other users (uploader's) speeds that u are dependant on..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Last edited by ashu888ashu888; 26-08-2008 at 11:53 AM. Reason: Automerged Doublepost
Old 26-08-2008, 02:09 PM   #42 (permalink)
i agree with ^
Regards
imageek is offline
Utorrent speed help!! 047 Software Q&A 6 10-08-2008 11:48 AM
Download using utorrent...pls help sesi5674u Internet & WWW 7 16-08-2007 05:31 PM
utorrent prob, upload speed is higher than download speed daemon Internet & WWW 2 17-07-2007 03:05 PM
ADSL Speed for Utorrent idea Hardware Q&A 2 08-07-2007 05:05 PM
utorrent can't download!! *GandaBerunda* Software Q&A 1 26-05-2007 05:56 PM
- by gforz
- by Piyush
