Old 18-07-2008, 12:09 PM   #1 (permalink)
MAK
MAK's Avatar
Red face help regarding partition.....
i just got hp pavilion 9550in yesterday
when i click on my computer i can see 2 partitions c289 gb) and d: factory image(8.39 gb)
my d partition has got a recovery file........
and windows vista is on c drive.....
so i want to ask that if can create more partitions from my c drive and how can i do this without losing anything on c and d ?
and which soft ware i should use to to this ??
MAK is offline
Old 18-07-2008, 12:10 PM   #2 (permalink)
Default Re: help regarding partition.....
GParted, Partition magic
ThinkFree is offline
Old 18-07-2008, 10:25 PM   #3 (permalink)
MAK
MAK's Avatar
If i create partition usin these software from c drive will my data on c be safe??
i told u my c is of 289 gb and i need to create new partition from c
and
i tried using partition magic it told me i dont have any logical partition
help me
plz
MAK is offline
Old 18-07-2008, 10:49 PM   #4 (permalink)
Web developer
narangz's Avatar
You have Windows Vista so you don't need any third party application for partitioning. Use Shrink in Windows Vista. Your data will be safe & you won't loose anything.
Here's how:
http://techiesrealm.com/blog/2008/04...windows-vista/
narangz is offline
Old 19-07-2008, 10:19 PM   #5 (permalink)
MAK
MAK's Avatar
Here's how:
thanx it worked
but got new problem
i shrinked my c from 289 to 228 and created new partition of 61 gb
but now i cant shrink my c more
stuck here
help
MAK is offline
Old 19-07-2008, 10:43 PM   #6 (permalink)
Web developer
narangz's Avatar
Check the comments in that link
narangz is offline
Old 20-07-2008, 02:58 PM   #7 (permalink)
MAK
MAK's Avatar
thanx again
MAK is offline
Old 20-07-2008, 03:22 PM   #8 (permalink)
Web developer
narangz's Avatar
My pleasure
narangz is offline
re-partition :) quad_master Hardware Q&A 2 08-07-2008 04:53 PM
not able to partition INS-ANI QnA (read only) 4 18-03-2008 02:14 PM
partition a used partition ashfahan Software Q&A 5 15-01-2008 12:48 PM
the C: partition iamtulipin QnA (read only) 4 23-02-2005 09:13 AM
