| Forum |
#1 (permalink) |
Its not a problem with the browser. When I do a tracert I find that it doesnt even reach the router. See the scrren shot below. ![]() As far as I know i havent made any significant changes on my router. Also the problem is with a select few sites not all. This is the current firewall settings on my router. (these are the default ones) I dont have a software firewall. ![]() please help. Any advice is appreciated. Thanks. |
#4 (permalink) |
Log in to your router and decrease the MTU Size to 1437 and ur connection will start working fine.
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
#5 (permalink) |
Legen-wait for it-dary!
Get the latest zonealarm pro if you had the old version... it doesnt work with the latest dns resolution patch from microsoft.
If the Start Windows Restart when Windows starts check box is checked Windows Restart will start automatically every time Windows is started. - Actual excerpt from a windows program help file |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Internet Connection Through Bsnl Wll | skghosh44 | Broadband and DTH | 1 | 18-10-2007 08:50 AM |
| P990i - BSNL Internet | gcbeldar | Mobiles and Tablets | 2 | 08-08-2007 09:49 PM |
| BSNL Internet Problem for 2 months | Harvik780 | Hardware Q&A | 7 | 02-08-2007 04:45 PM |
| Can I get BSNL internet connection? | fatguysmart | Broadband and DTH | 5 | 10-01-2007 02:28 PM |
