17-07-2008, 01:18 PM
Gracias Senor
Connecting 2 offices together...
Hi all..
My office in delhi has a branch in chennai too..I am planning to setup a server here in delhi office so the chennai office can access the server.
1. How is the above process accomplished??
2. What are the devices I require??
Pls let me know a solution ASAP.
T i A
16 vews!!!! no one knws the answer???? cum on techies..help me out.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
Reason: Automerged Doublepost
17-07-2008, 11:36 PM
Re: Connecting 2 offices together...
The easiest way would be to create a VPN(virtual private network) between your Delhi and Chennai office. This way you would only need to have an internet connection at both your offices and no extra devices. But your Delhi office server will need to have a static ip address. You can still connect your offices through a VPN without a static ip, but your Chennai office will have to call up your Delhi office to ask for the ip of the server everytime before connecting.
Assuming you are using windows XP, it has a built-in feature for creating VPN's but I found OpenVPN to be much more reliable and easier to setup. You will need to download the GUI for OpenVPN seperately.
You can use OpenVPN from the commandline but the GUI makes it very convenient and easy to use. OpenVPN is free and secure. Your Chennai office will need to have a key generated on your Delhi server before they can connect, its like a really long password.(don't have to generate the key everytime, just once or whenever you want)
Direct download: OpenVPN v2.0.9 and GUI v1.0.3
17-07-2008, 11:45 PM
java is fun.
yah VPN is the perfect way to do that
18-07-2008, 09:49 AM
Gracias Senor
^^ thnx for the reply..We are now purchasing a IBM Server, Static IP from Airtel. So this is enough for the VPN.
Is there a need to go for a router??? One in delhi and one in chennai???
Edit - Can any1 help me with my query???
21-07-2008, 06:59 AM
java is fun.
If you are asking for establishing a vpn only. Than in that case my answer is no you dont need a router.
21-07-2008, 11:12 AM
Gracias Senor
^^ I am totally confused now..Which one is better???? Connecting thru VPN or Router???
If VPN, how to implement it and make it to work???
If with Router, how to implement and make it to work???
Techies pls help me out.
22-07-2008, 12:28 AM
For setting up a VPN, you don't need to buy any extra hardware. But to create a VPN, you will need to get your server and your client machines connected to the internet. So in order to get your comps connected to the internet, if you have to buy a router(or any other hardware), then buy it. Once you get your server and client comps connected to the internet, then setting up a VPN is software all the way.
22-07-2008, 02:42 PM
Gracias Senor
^^ so vpn can be achieved by using a software??
22-07-2008, 03:09 PM
Deadman Walking
First tell if there is any logical connectivity between two offices ?
LAN->MODEMS->DELHI ROUTER,,,,,,,,,,,,,,,<ISP>,,,,,,,,,,,,CHENNAI ROUTER<-MODEMS->LAN
IS this what you want, where delhi LAN has one IBM ADS Server
Or you want only delhi server in GUI ?
Are you using any FIREWALL ?
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
24-07-2008, 11:41 PM
Yes, a VPN is achieved by using software. The software creates a tunnel through the internet, between your server and client.
image source
25-07-2008, 09:17 AM
Gracias Senor
here it is..
Delhi - One broadband modem from Airtel.
ISP - Airtel
15 computers
No firewall.
Chennai - One broadband modem from Airtel.
ISP - Airtel
7 computers
As of now there is no connectivity b/w chennai and delhi.
Here is the plan.
1 central server wil b in delhi.
All 15 computers will be connected to the central server.
Also chennai computers must be connected to the central server.
As of now we have asked for a static ip from Airtel for the server.
Now how is the connectivity gonna be done.
We need to minimal the cost and so VPN is the connectivity medium.
In the above scenario how should I go for the VPN??
