Old 17-07-2008, 12:42 PM   #1 (permalink)
smile's Avatar
Angry Hard disk problem
Hi........
The problem is am not able to boot into HDD ............I have 80 GB Sata hdd ..I have check the bios its detecting in bios ....but when i boot up the error msg am getting is "IDE Primary Master S.M.A.R.T has been diabled". What is this S.M.A.R.T ? Where can i enable it? I even checked the Bios settings but i could not find..Everything i did i changed the cable , then i made it as slave and even i connected my HDD to other system but the same error am getting . Please can anyone help me
SR
smile is offline
Old 17-07-2008, 01:38 PM   #2 (permalink)
Web developer
narangz's Avatar
Default Re: Hard disk problem
SMART:
http://en.wikipedia.org/wiki/Self-Mo...ing_Technology
You can enable or disable SMART monitoring in BIOS.
narangz is offline
Old 17-07-2008, 02:07 PM   #3 (permalink)
smile's Avatar
Red face Re: Hard disk problem
@narangz: thanks a lot ............good tutorials but how to disable in bios
SR
smile is offline
Old 17-07-2008, 05:47 PM   #4 (permalink)
-----ATi-----
nvidia's Avatar
It might be there under the miscellaneous option..
http://twitter.com/akshayms
nvidia is offline
Old 17-07-2008, 06:03 PM   #5 (permalink)
Web developer
narangz's Avatar
It depends. Most of the motherboards have the SMART enable/disable option on the main page itself. It might even be labelled (SMART) HDD/Hard Disk Monitoring or something like that.
narangz is offline
Old 17-07-2008, 06:05 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
Google your motherboard name and get the manual for it. Maybe you'll find it there..
nvidia is offline
Old 17-07-2008, 06:08 PM   #7 (permalink)
left this forum longback
praka123's Avatar
go to BIOS and enable "enhanced mode" in sata /ide section.
praka123 is offline
Old 17-07-2008, 06:10 PM   #8 (permalink)
Web developer
narangz's Avatar
^^ Is that you praka, without cat?
narangz is offline
Old 17-07-2008, 08:37 PM   #9 (permalink)
smile's Avatar
Unhappy Re: Hard disk problem
Hm.............One thing i want to know i have connected the same HDD to other system and there too its showing me the same error Can any one tell me why
SR
smile is offline
Old 17-07-2008, 09:34 PM   #10 (permalink)
Web developer
narangz's Avatar
Umm... Have you checked your motherboard manual for SMART?
narangz is offline
Old 18-07-2008, 11:30 AM   #11 (permalink)
Amir.php's Avatar
^^i dont know why, but i feel many times that he does not follow the thread instructions.
Because it is repeated thread and i already have been gived this idea to him, but he never replied.
in some other thread also.
Amir.php is offline
Old 19-07-2008, 11:54 AM   #12 (permalink)
you can also check hard disk power cable & data cable
Originally Posted by smile View Post
Hi........
frzkhn is offline
Old 19-07-2008, 03:54 PM   #13 (permalink)
smile's Avatar
@Amir.php :- sorry yaar actually at that time i had given my hard disk for data recovery and i was waiting to recover my data .....they told me to connect my HDD to other system and take the back up . I recovered my data but HDD is still having the same problem.
@frzkhn:- Yes i have changed the power cables and SATA cables .........but the problem is same
SR
smile is offline
Old 19-07-2008, 08:07 PM   #14 (permalink)
Amir.php's Avatar
^^ok, but why you are not following narangz and me?
first follow what narangz saying?
Amir.php is offline
Old 19-07-2008, 08:32 PM   #15 (permalink)
i dont think disabling the S.M.A.R.T feature will stop it from booting up....
If so then there seems to be some problem with ur BIOS or ur Hard Drive.
try these followings :
1.reset the bios to default settings.
2.try to reset the BIOS by changing a jumper setting on ur motherboard(if available on ur motherboard) *
3.remove the System battery and short the two ends of the batterry holder on the motherboard for more than 3 seconds *
*these settings r to be done wen power is OFF.
Warning!!!!....this solutions could harm ur system if ur not familiar enough with the hardware.....BEWARE!!!
contact a qualified Engg Instead.
rohitkorde is offline
Problem With DVD? or Hard Disk? or Something Else thetillian QnA (read only) 3 29-06-2008 11:36 AM
hard disk problem,please help devj Software Q&A 4 04-03-2006 03:47 PM
Hard Disk Problem valtea QnA (read only) 4 14-06-2005 07:15 PM
hard disk problem aditya169 QnA (read only) 6 30-05-2005 08:48 AM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
