| Forum |
#1 (permalink) | |
I am using Airtel Gprs connection in my SonyEricsson W300 EDGE phone,i use XP,using pc suite i connect to net.i set my baud rate to be 921kbps,i am living in a area which is EDGE enabled.The problem i am facing is very slow browsing and downloading speed(1-3kps),where as with same phone and same connection i get my download speed to be 7-12kbps.i called up Airtel Customer care,they replied no problem in their side.. i ve two question!! 1.Wat is optimum baud rate to be set? 2.wat happened to net speed which i get two weeks before? (i use AVG8.0 with updates so i think there no chance of malware or any trojan) Thanks in Advance, Quote:
------------------------------------------------------------------------------------------------------ Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Documents and Settings\Ganesh>tracert www.yahoo.com Tracing route to www.yahoo-ht3.akadns.net [209.131.36.158] over a maximum of 30 hops: 1 * * * Request timed out. 2 * 3073 ms 1637 ms 10.5.13.1 3 738 ms 899 ms 880 ms 10.5.13.50 4 646 ms 437 ms 420 ms 10.5.12.81 5 453 ms 582 ms 460 ms 125.17.110.179 6 623 ms 442 ms 395 ms 125.17.109.97 7 422 ms 517 ms 501 ms 125.21.167.25 8 742 ms 681 ms 935 ms 12.86.240.17 9 841 ms * 1701 ms tbr2.la2ca.ip.att.net [12.122.104.90] 10 1160 ms 797 ms 821 ms cr2.la2ca.ip.att.net [12.122.19.205] 11 838 ms 1078 ms 1361 ms cr2.sffca.ip.att.net [12.122.31.134] 12 1035 ms 1282 ms 636 ms tbr1.sffca.ip.att.net [12.122.19.6] 13 * 1412 ms 839 ms 12.122.110.25 14 602 ms 910 ms 893 ms 12.86.154.18 15 2512 ms 1320 ms 1175 ms ae0-p150.msr2.sp1.yahoo.com [216.115.107.73] 16 1138 ms 1202 ms 1015 ms te-9-1.bas-a1.sp1.yahoo.com [209.131.32.21] 17 651 ms 1061 ms 1019 ms f1.www.vip.sp1.yahoo.com [209.131.36.158] Trace complete. ------------------------------------------------------------------------------------------------------- C:\Documents and Settings\Ganesh> Last edited by sganesh; 17-07-2008 at 12:00 PM. Reason: Automerged Doublepost |
#2 (permalink) |
Try closing all the programs which may connect to the internet(including AV updater, avg updater including firewall) and then see what speed you get? Once It happened with me that Comodo Firewall was reducing the speed to 3-4kbps and on closing it, speed used to become normal.
#6 (permalink) |
i cant understand what you wanna say firstly you write "is very slow browsing and downloading speed(1-3kps),where as with same phone and same connection i get my download speed to be 7-12kbps"
what does this mean ?? plz clr Thanks Regards..... Expertno.1
Off From Digit Forum for some months.....busy |
#7 (permalink) | |
but now its 1-3 kbps!!!. |
#8 (permalink) |
Since you are using mobile to connect to internet, so one reason could be because of the weather.To strengthen the signal go around the house and try to find a place with the strongest signal.If you are using bluetooth, change it to data cable to connect your mobile with your PC.
Another important reason could be because your mobile is now catching signals from a tower which has weaker capacity.Therefore, you are not getting same speed as before.Try to turn your mobile into diferent directions to find the tower with the strongest signal. And most important of all:MAKE AN ANTENNA TO TRIPLE YOUR SIGNAL. Once you find the "right location and direction", your speed is bound to increase as I have also applied these tricks and my speed has remained constant almost throughout the day(and night as well). __________________________________________________ ______________________ THOU SHALT NOT COPY WHAT IS NOT YOURS. Last edited by Hok; 18-07-2008 at 11:08 PM. |
#9 (permalink) |
Banned to Spam
Location: Look below...not under pants dumbo...use a GPS
Belive me for once try uninstalling AVG and run your browser, if you are getting the same low speeds, then try what HOK said. I told you this because AVG 8 has a WEB SHIELD feature, which scans the opened website in AVG and then it shows the webpage, making it too slow, or else try other browser like Firefox or Mozilla.
My DeviantART page now exists !!! Krazy-Bluez.deviantart.com Twitter: http://twitter.com/KrazyBluez |
#10 (permalink) |
there could be three reasons for ur problems according to me
1.Virus/Trojan on ur PC or ur Phone which eats up processing time/network usage 2.Connectivity issues(i have used Airtel GPRS services myself for some time on my PC..and it really gets slow sometimes)....u may be getting less bandwidth due to increased load in ur area or signal strength may be low on ur phone. or there may be some issues on the server @airtel |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Airtel mobile gprs vs Airtel MO gprs for PC | phuchungbhutia | Chit-Chat | 5 | 04-12-2007 03:23 PM |
| Airtel Gprs Speed Problem | almighty | Broadband and DTH | 3 | 24-06-2007 06:29 PM |
| Airtel Gprs | saiaspire | Mobiles and Tablets | 4 | 04-05-2006 04:53 PM |
| Airtel GPRS | freezer | Broadband and DTH | 12 | 05-03-2005 04:32 PM |
