Old 16-07-2008, 03:13 PM   #1 (permalink)
Indidiot
Plasma_Snake's Avatar
Exclamation XP SP 3 Problem
I installed the SP3 given in the June DVD of Digit. Now I cannot change my Theme. No matter whichever one I select, it doesn't changes only the animation that says Please Wait is displayed and nothing changes. The XP I'm using had Vista Transformation Pack preinstalled in it with few registry hacks like Copy To, Move To etc. Also please tell me how can I create a bootable XP SP3 DVD from my current installation coupled with few softwares of my own choice?
Plasma_Snake is offline
Old 16-07-2008, 08:33 PM   #2 (permalink)
Amir.php's Avatar
Default Re: XP SP 3 Problem
VTP is not workable on xp sp3.
uninstall it.
Amir.php is offline
Old 16-07-2008, 09:28 PM   #3 (permalink)
Indidiot
The question is that now my boot screen and theme is Windows default no matter which Theme I select . What is the probable problem and its solution, please help
Old 16-07-2008, 09:44 PM   #4 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Get the latest UXTheme patcher for SP3 which will allow you to use custom visual styles. If you want those Vista-like animations and effects, try the Vista Inspirat Bricopack from CrystalXP.net. It's much better than VTP, IMHO.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 17-07-2008, 02:00 PM   #5 (permalink)
Indidiot
Thanks a lot, UX Patcher did the trick. I downloaded the Brico Pack but didn't installed it because before taking the plunge wanted to clarify the issue that is it permanent like Transformation Pack or can be un installed?
Old 17-07-2008, 05:37 PM   #6 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Don't worry, Bricopack can be easily uninstalled. It places all its files in a folder named Bricopacks in the Windows directory and takes a backup of any files it replaces.
Flickr!
Kl@w-24 is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by gforz
- by Piyush
