Old 15-07-2008, 11:06 PM   #1 (permalink)
Default Problem playing Movies on RealPlayer!!
I have been trying to play movies by using RealPlayer's inbuilt browser. The problem is that the movies play like SlideShow while the audio plays continuously. I thought it to be problem with the slow connection and hence allowed the movie to download (in the cache as RealPlayer doesn't allow full movies to be stored on the comp.) first and then play it. But even then the output remains the same. What should I do?
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline
Old 16-07-2008, 07:14 AM   #2 (permalink)
Amir.php's Avatar
Default Re: Problem playing Movies on RealPlayer!!
^^ Which Browser You are Using?
Amir.php is offline
Old 16-07-2008, 11:48 AM   #3 (permalink)
I am using RealPlayer's inbuilt browser which is the only access to movies on RealPlayer's website.
monkey is offline
DVD writer not playing movies well.. ramsingh QnA (read only) 3 10-04-2008 06:04 PM
DVD ROM not playing movies er_gurpreet Software Q&A 1 03-11-2006 09:06 AM
problem playing dvd movies cybertooth QnA (read only) 1 17-09-2006 12:11 PM
Movies not playing ! cyberzook Hardware Q&A 5 15-11-2005 06:27 PM
which is the best codecs pack for playing movies iamtulipin QnA (read only) 1 17-02-2005 01:03 PM
- by gforz
- by Piyush
