Old 15-07-2008, 03:19 PM   #1 (permalink)
rhasta's Avatar
Angry Local Area Network problem
hi friends
i am using mtnl triband which suxx to the core
my problem is that sometimes when i open heavy sites such as facebook etc. the lan connection icon in the system tray stops blinking and stops responding
after this happens i cant disable the connection due to which my comp does not shut down immidiately and the end now screen shows up
after i select end now(while shutting down) the desktop becomes blank and it stays like that for a long time(5-10 mins.).Then i have to directly off the switch of my comp.
sad
wat should i do?
can anyone help me?
thnxx
rhasta is offline
Old 15-07-2008, 05:28 PM   #2 (permalink)
dhanusaud's Avatar
Default Re: Local Area Network problem
may be there is a virus in your system. Get a full scan your system with well update KAV or NOD32.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 15-07-2008, 09:12 PM   #3 (permalink)
afonofa's Avatar
Lightbulb Re: Local Area Network problem
After the system tray icon stops blinking and responding, did you try closing browser/ending browser process and turning off the router?
afonofa is offline
Old 16-07-2008, 07:33 AM   #4 (permalink)
Amir.php's Avatar
Try Here:
http://e.domaindlx.com/svenkatesh/pcpages/XPMODEM.HTM
Amir.php is offline
Local Area Connection taking lot of time to load...! jack_the_ripper QnA (read only) 3 18-12-2007 07:28 PM
Local Area Network Notification Icon in System Tray ilugd Open Source 11 27-05-2007 03:04 PM
Network area not showin' blueshift Mobiles and Tablets 5 03-02-2007 03:56 PM
local area network pranavrahul Software Q&A 5 11-01-2007 09:37 PM
Their is no local area connection after i format my computer, help zycon Hardware Q&A 6 05-09-2006 08:52 PM
- by gforz
- by Piyush
