Old 13-07-2008, 11:49 PM   #1 (permalink)
mohitgiri's Avatar
Default flv to avi converter
hi friends plz tell me about a flv to avi converter which is freeware and works really fast.
regds
MOHIT GIRI GOSWAMI
mohitgiri is offline
Old 14-07-2008, 12:11 AM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: flv to avi converter
any normal video transcoding and transmuxing suite would work well.
you could use common stuff like MeGUI, MediaCoder, MEncoder, FFMPEG, SUPER, VLC, etc.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 14-07-2008, 12:12 AM   #3 (permalink)
Kiran.dks's Avatar
Freeware: Super Converter
Online Free Convertion: http://www.videoconverterdownload.co...converter.html
Kiran Kumar R
Kiran.dks is offline
Old 14-07-2008, 12:37 AM   #4 (permalink)
The Smaller Bang
most online converters are BS and are just bandwidth wastes.
Old 14-07-2008, 12:40 AM   #5 (permalink)
Kiran.dks's Avatar
They are not bad. It comes in handy sometimes. I have trouble installing Super Converter because Spysweeper thinks it has some malware. I do it online. I really don't worry about bandwidth. I have a 15Mbps unlimited connection!
Kiran Kumar R
Old 14-07-2008, 12:44 AM   #6 (permalink)
The Smaller Bang
Well, then either your spysweeper is stupid or super is crapped out.
15mbps unlimited ? Speed will still suck. You need to upload, wait for the server to transcode then download. Besides, you have NO control over the video quality.
Old 14-07-2008, 12:51 AM   #7 (permalink)
Kiran.dks's Avatar
My reply is specific to this thread. People commonly view FLV format in You tube and they wish to rip them to avi and save them to PC. The link does exactly the same. I tried it many times.There is no need to upload. Just give the You tube link and it rips off for you. All you need to do is download the ripped video. I also didn't see noticeable loss in quality.
Kiran Kumar R
Old 14-07-2008, 12:55 AM   #8 (permalink)
The Smaller Bang
Its not about noticable loss in quality. Its about absolute quality.
In VLC for instance, I can call the FFMPEG PostProcessing filter and apply it at level 6 twice before piping it back to FFMPEG for transcoding. This would give me a dramatically better quality.
And as for YouTube, you should try KeepVid. It gives download link of the higher quality MP4 version of each video in youtube, which is otherwise hidden.
Old 14-07-2008, 01:43 PM   #9 (permalink)
Hi!
You can try to use VideoCharge for it!
Very nice batch mode functions!
NVTRicc is offline
.rm to mp3 converter ARJOT SINGH Software Q&A 12 06-07-2010 08:53 AM
Mp4 to Avi Converter Krish_88 QnA (read only) 2 05-01-2008 07:04 PM
How to use 3gp converter? mandar5 Software Q&A 1 15-09-2006 04:44 PM
mp3 to amr converter Spawn Freak Mobiles and Tablets 2 14-08-2006 01:59 AM
- by chris
