Old 12-07-2008, 10:42 AM   #1 (permalink)
047
047's Avatar
Question Vista help plz !! urgent!!
Hi i got my laptop HP 520 Notebook 2 months back. I formatted the preinstalled vista starter and installed xp on it becoz i had to use vb.net 2005. now i want to get my vista starter back. Is there any way to get it back?
Plz help me someone? can recovery disc help me?
047 is offline
Old 12-07-2008, 12:01 PM   #2 (permalink)
D@rekills4's Avatar
Default Vista CD
Didn't you get a CD of Vista along with it?
My father has a Toshiba Laptop and he got a CD with it which formats the drive you want and then Installs XP automatically if the drive containing the window has been formatted!
D@rekills4 is offline
Old 12-07-2008, 12:43 PM   #3 (permalink)
Web developer
narangz's Avatar
Default Re: Vista help plz !! urgent!!
Have you created the recovery discs? If yes, simply boot from those recovery discs & follow the instructions & Vista will be back. However backup your data as it may format the whole hard drive.
If you haven't created the recovery discs, then you will have to order them from HP & pay for them.
narangz is offline
Old 12-07-2008, 08:10 PM   #4 (permalink)
The Paparazzi Continues..
u can do that only if u hav d recovery discs....if u havnt created d discs den ask ne of ur frenz who may hav same laptop model.recovery discs of ne HP 520 Notebook can reinstall vista.
by d way, vista do run vb.net 2005....i hav used vb.net 2005 in vista.....
plz do reply in case of ne problem.
soumyajit_nayak is offline
Old 12-07-2008, 10:02 PM   #5 (permalink)
Web developer
narangz's Avatar
^^ You need to download an update for VS.net 2005 to run it on Vista
narangz is offline
Old 18-07-2008, 01:37 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Game messenger
FRANKLY.. DON'T EVEN BOTHER INSTALLING VISTA STARTER. Its the biggest piece of crap ever produced by MS. If you wanna go in for Vista, then I'd suggest Home Premium or stick with XP.
infra_red_dude is offline
urgent vista issue sushantsaurabh Software Q&A 5 03-03-2008 11:36 AM
Office 2007 and Vista problem...Urgent### Abhishek Dwivedi Software Q&A 4 09-02-2008 01:37 PM
Vista over XP...... Urgent advice needed hmvrulz Software Q&A 9 08-04-2007 02:25 PM
Urgent...Disk Read Error ....Now Wid Vista BBThumbHealer Software Q&A 5 25-03-2007 05:19 PM
My Vista ISO has dissapeared. Help me urgent! aryayush Software Q&A 10 24-09-2006 02:23 PM
- by chris
