Old 11-07-2008, 07:13 AM   #1 (permalink)
cooldip10's Avatar
Default WINRAR-- need HELP Urgently!!
Hi guys..
I somehow forgot password of the RAR file which I downloaded from net a year ago.
Now I am unable to retrive it from anywhere..
Tried searching for programmes which can break the password.. But futile.
Can anybody help.. I need the file very very urgently..
Everything is Possible
cooldip10 is offline
Old 11-07-2008, 11:43 AM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: WINRAR-- need HELP Urgently!!
this is not the solution but may help you,
How to open password protected rar file???
anyhow try http://atomic-rar-password-recovery.....qarchive.org/
and rar cracker softwares
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 11-07-2008, 03:00 PM   #3 (permalink)
D@rekills4's Avatar
Default ZIP Password Finder
I had a ZIP Password Finder but I removed it cause I never used it
And mostly passwords are the website names from where you downloaded
But if the user has already given it a password then you are unable to crack it
D@rekills4 is offline
Old 11-07-2008, 03:04 PM   #4 (permalink)
Fullbring
Zangetsu's Avatar
remember all password cracking use hit & trial method....like brute-force,dictionary
attack...etc
it will depend on the password length that how much it will take 2 recover...
it can take years when the earth is near its end... cant predict...
so...goodluck & keep trying
Zangetsu is offline
Old 12-07-2008, 08:00 AM   #5 (permalink)
cooldip10's Avatar
Thanx for the wishes guys.. Anymore suggestions??
Old 12-07-2008, 08:13 AM   #6 (permalink)
anarchist
Posts: n/a
I have found password of a rar file with password cracker software, it took 5 minutes to crack 5 character password with brute force (small & caps, symbols, numbers included)
pm me if you want it
Old 12-07-2008, 10:16 AM   #7 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
do a google search with the rar file name like something.rar+password,try different combination's.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 12-07-2008, 10:23 AM   #8 (permalink)
It doesn't matter!
Sumeet_naik's Avatar
I've used a password finder and it worked.. Use brute-force.. And depending upon ur processing speed of pc its gonna take tat much time.. It took somewhere around 3-4 days for 7letter word wit alpabets only..
Twitter - http://twitter.com/Sumeet
Blog - http://sumeetnaik.blogspot.com
Lenovo Y410 775787Q + SE K530i
Sumeet_naik is offline
Old 13-07-2008, 08:10 AM   #9 (permalink)
cooldip10's Avatar
FOUND IT !! FOUND IT!!
SEARCHED THE WEB WITH EXACT FILE NAME AND FOUND IT!!!
Thanx for all your help guys! Thanx all once again..
Old 14-07-2008, 10:56 AM   #10 (permalink)
anarchist
Posts: n/a
for 5 charcter password time will be ~5 minutes
for 6 charcter it will be ~ 5 x 100 = 500 minutes = 8Hours
(26small lettwr+ 26caps + 10num + symbols)
and for 7 charcter it will be 8 x 100 = 800 hours
and so on.....
Old 14-07-2008, 11:07 AM   #11 (permalink)
Dude you found the software but it'll be MOSTLY impossible for you to retrieve the password and WinRAR encryption is very very strong so it may take even months to crack that password depending on its length and your CPU power.
Xccentricity is offline
Old 14-07-2008, 04:02 PM   #12 (permalink)
Come get Some
DukeNukem's Avatar
Talking Re: WINRAR-- need HELP Urgently!!
Originally Posted by cooldip10 View Post
Hi guys..
Well I think you should forget about this File and delete it (lol) as this is what i do in similar cases (make a free space for you). Password Cracking softwares are just Fake Hope to recovery the passwords
Computers are like Air Conditoners, thet stop working properly when u open WINDOWS.
DukeNukem is offline
Old 14-07-2008, 04:20 PM   #13 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^I think u shud read the reply above urs he got the password
zyberboy is offline
Old 28-01-2009, 07:19 PM   #14 (permalink)
please give me the link from where i find this software
i try to search to i cannot get it
one in have download but it has password
kuhupihu is offline
Old 28-01-2009, 10:52 PM   #15 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ www.elcomsoft.com
Not free, but warez versions work beautifully
dheeraj_kumar is offline
Old 29-01-2009, 04:52 PM   #16 (permalink)
Fresh Stock Since 2005
thats what I do every time I lose a rar password...
http://www.khattam.info
khattam_ is offline
Old 29-01-2009, 09:49 PM   #17 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Search the net and ahem sites, there's a program that lets u extract password protected rars, jus' can't recall the name.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Winrar smile Software Q&A 6 17-11-2007 09:28 AM
Beware of WinRAR.com ! anandk Technology News 18 29-06-2007 05:09 AM
Winrar shivam Mobiles and Tablets 2 13-11-2006 08:51 PM
WinRAR 3.61 qudra Technology News 4 14-09-2006 10:56 PM
How to do with Winrar ?? saROMan Software Q&A 4 27-04-2005 11:13 AM
- by chris
