Old 10-07-2008, 01:47 PM   #1 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Default Problem Connecting Internet
Hi
I recently connected my PC with my frnds lappy
But after that my ZA firewall is acting absurdly & isn't allowing me to connect using internet
I get connected but no website opens up
I try to ping the BSNL server & it works fine
But still no website opens
When I disable ZA Firewall it works fine
I tried to reinstall ZA but the same problem persists
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 10-07-2008, 04:26 PM   #2 (permalink)
afonofa's Avatar
Lightbulb Re: Problem Connecting Internet
I'm not sure if its because of connecting to your friend's laptop. But if you installed the latest windows updates, Microsoft Update KB951748, then you could be having the same issue(loss of internet connection with zonealarm firewall on) that lots of zonealarm users have reported after installing those updates. They have released a new version of zonealarm firewall which fixes this issue.
v7.0.483.000
afonofa is offline
Old 10-07-2008, 05:55 PM   #3 (permalink)
Ecko's Avatar
Default Re: Problem Connecting Internet
Problem Solved
Thanx Very Much
Ecko is offline
Old 12-07-2008, 12:41 PM   #4 (permalink)
I'm also facing the same problem.
in my computer automatic update was turned on,after that all mails(yahoo,gmail)even orkut are not opening.
even a page is taking quite long to load.
but downloads are working fine.
as per the procedure u had told,i couldn't find Kb951748 update installed.
is it anything to do with virus?
or what is the procedure so that this problem can be solved...
plz reply
snehangshu is offline
Old 12-07-2008, 01:26 PM   #5 (permalink)
Tech'ing life seriously!!
sude's Avatar
dear snehanshu..
download Kb951748.. from www.microsoft.com/downloads/details. aspx?familyid=ed989a33-7a9e-4423-93a8-b38907467cdf
or install the latest za version v7.0.483.000 from http://download.zonealarm.com
SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 17-07-2008, 11:05 AM   #6 (permalink)
the page u r talking about it says"page cannot be displayed"
also i'm using avast antivirus.
is it blocking the sites/mails from opening?
whenever i was opening my computer,avast detected 6/7 virus and I deleted all.
what to do next?
Old 18-07-2008, 12:00 AM   #7 (permalink)
sude's Avatar
dear snehanshu... try this link www.snipurl.com/308qk
let us kno wht happnd..
SUDE
sude is offline
Old 18-07-2008, 12:16 AM   #8 (permalink)
afonofa's Avatar
The above solution was only if you have zonealarm firewall installed and then had a complete loss of internet connection after the KB951748 windows update. Even if you don't have zonealarm you should still be having the KB951748 update because it is a critical security update.
At the top of your Control Panel > Add/Remove Programs there is a checkbox for Show Updates. If that checkbox is checked and you still can't find KB951748 in the updates list then download and install KB951748.
If you have zonealarm installed and you have the KB951748 windows update already installed, then your internet connection problem is because of ZA conflicting with the windows update. In that case get the latest zonealarm v7.0.483.000 which works with update KB951748.
If you don't have zonealarm and you also don't have KB951748 update then maybe installing only the windows update will solve your problem.
If it doesn't, then from what you said about viruses, that is probably the reason for your loss of internet connection. In that case I recommend you uninstall Avast, download and install Kaspersky Antivirus v7.0.1.325 > activate the trial > update it > scan and clean. If Kaspersky cleans out all the viruses then you can continue using it till the trial ends and then switch back to Avast or buy Kaspersky Antivirus.
If you still have virus problems, then maybe post a HijackThis log in a new thread.
Edit: I mean my above post.
afonofa is offline
Problem while connecting to internet through LAN... mad_hatter_11 Software Q&A 1 27-03-2008 10:11 AM
connecting to internet via bluetooth trublu Software Q&A 3 21-01-2008 07:56 PM
Connecting to internet sattumail Internet & WWW 8 28-02-2007 12:18 PM
Connecting to Internet from Suse udhaya Open Source 22 06-06-2006 01:49 AM
Internet -Connecting Problem -Fedora Core3 karthik_rcs Open Source 3 24-03-2005 04:41 PM
- by chris
