Old 10-07-2008, 01:42 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
tango_cash's Avatar
Default Kaspersky is hanging my system!!!gives a error.Pls help.
my system config is as follows-
2.8 Gz Pentium 4 (H.T) processor(the hot one)
915 GAV Intel orignal motherboard
1.75 GB
Segate 250GB+320GB Harddisk
i installed kaspersky 7.0.1.325 c.d on my system.earlier it was working fine but recently it has started causing problems for me.
my system suddenly hangs and after some time a window pops up saying "Previous application launch failed." in this kaspersky lists some files which it asks to send. i click cancel,then the system works fine ,then after sometime it would againg hang and the same error will pop up.i even clicked on the send button but nothing happens.
here is the screen shot of that.
pls help. is any one else getting this error.
tango_cash is offline
Old 11-07-2008, 07:47 PM   #2 (permalink)
y2j826's Avatar
Default Re: Kaspersky is hanging my system!!!gives a error.Pls help.
use AVAST antivirus its best one for home users (free edition), u can download it from my weblink http://h1.ripway.com/worldofy2j
y2j826 is offline
Old 11-07-2008, 08:56 PM   #3 (permalink)
afonofa's Avatar
Lightbulb Re: Kaspersky is hanging my system!!!gives a error.Pls help.
Go to Settings > Update > uncheck Update application modules > OK
Then update your antivirus signature and after the update go back to
Settings > Update > check Update application modules > OK
Last edited by afonofa; 12-07-2008 at 07:41 AM. Reason: i read the post instead of just looking at the SS :p
afonofa is offline
Old 22-07-2008, 05:58 PM   #4 (permalink)
tango_cash's Avatar
thanks for the reply but i removed it and now using nod32 and comodo.
Old 25-07-2008, 05:54 AM   #5 (permalink)
Boom Boom Boom
cooldudie3's Avatar
I think Avast is quite wimpy and does not work well. If Avast was free, every AV company would have to close!
I'm back! Gimme a hugggggg... :D
cooldudie3 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/software-q/92667-kaspersky-hanging-my-system-gives-error-pls-help.html
Topic About Previous-application-launch-failed:-Kaspersky | diod.biz This thread Refback 26-04-2012 11:54 AM
Why my system/window is hanging? gaurav_indian Software Q&A 46 08-12-2007 12:21 AM
System Hanging smile Hardware Q&A 1 14-11-2007 04:20 PM
Download Kaspersky Anti-Virus 7.0 and Kaspersky Internet Security 7.0 for Win Vista Third Eye Technology News 31 22-10-2007 12:18 PM
lsass.exe system error??????? yoursfriend Software Q&A 6 14-11-2006 02:54 PM
getting system error in system32 rajesh_verma Software Q&A 1 11-03-2006 08:03 PM
- by chris
