Old 10-07-2008, 11:28 AM   #1 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Help, a virus attack,only desktop's wallpaper showing, wat to do?
Hi,
I m here with another prob
After i removed virus, i m getting only the wallpaper in desktop and nothing else.
I mean no start menu, no desktop icons no right click & left click. But only my desktop wallpaper is there shown.
I m able to run task manager through Ctrl+Alt+Del.
And I have run sfc /scannow, it asks me for my Win XP SP2 CD. It says some files r need to be copied to dllcache, when i inserted Win XP SP2 CD, then also it is not taking these files. I m inserting the right CD, then also nothing happens when i click on retry.
SO, wat to do?? Pls help.
Blogging at:
Technostarry
saqib_khan is offline
Old 10-07-2008, 03:08 PM   #2 (permalink)
Tech'ing life seriously!!
sude's Avatar
Default Re: Help, a virus attack,only desktop's wallpaper showing, wat to do?
well well..
its good than u r able to open Task Manager...
Open task manager...
under Applications Tab.. click on NEW TASK.
enter EXPLORER and hit enter..
u shd get back ur desktop icons etc..
SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 10-07-2008, 03:34 PM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
Nope, when i type explorer.exe, it says "Make sure u typed the correct name...."
Blogging at:
Technostarry
Old 10-07-2008, 03:48 PM   #4 (permalink)
sude's Avatar
then i think ur sys is affected wid virus whichs stopping u frm executing explorer.exe.
SUDE
sude is offline
Old 10-07-2008, 04:07 PM   #5 (permalink)
AFK
thewisecrab's Avatar
are you able to boot in safe mode?
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 10-07-2008, 04:33 PM   #6 (permalink)
afonofa's Avatar
Lightbulb Re: Help, a virus attack,only desktop's wallpaper showing, wat to do?
Its possible that the virus had infected(or deleted) explorer.exe and your antivirus either quarantined or deleted the file. If you are sure the virus has been completely cleaned out then you can try booting your comp into dos and copying a clean copy of explorer.exe into your %systemroot% folder. By default it is C:\Windows\
afonofa is offline
Old 10-07-2008, 04:49 PM   #7 (permalink)
I M A *STAR*
saqib_khan's Avatar
The problem's solved.
I copy & pasted explorer.exe from another system to my C:\Windows.
The virus deleted this file.
Thanx for all ur replies.
Blogging at:
Technostarry
Old 02-11-2008, 03:54 PM   #8 (permalink)
I thank you for the replies on this thread. Got this problem a little while ago.
Takazaki is offline
virus attack nims11 Software Q&A 8 04-05-2008 05:41 PM
Virus Attack skippednote Software Q&A 3 11-02-2008 03:34 PM
Virus Attack ruthless Software Q&A 17 24-04-2007 08:54 AM
A virus attack?? Manshahia Software Q&A 5 15-02-2007 09:37 PM
Virus Attack FasTrack Software Q&A 14 06-11-2004 12:11 AM
- by chris
