Old 09-07-2008, 11:44 PM   #1 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Unhappy HD problem
i install partition magic and merging the partition but the partition not merge after that i restart my pc then its showing the boot screen but window not booting it show
1-Microsoft Window XP Professional
2-Microsoft Window XP Professional(on volume 1)
3-Microsoft Window XP Professional(on volume 4)
if i logon to first window its start booting and only showing XP bar going left to right but the window not boot.and when i login to second window it give message window could not start because the following file is missing or corrupt;
<window root>\system32\hal.dll plaese re-install or copy of the above file
then insert Xp cd its also not working just only the first message comes checking ur hardware configuration then cd stop i don't wat the wrong with HD any 1 face this problem or recognize this problem
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 10-07-2008, 12:04 AM   #2 (permalink)
prasad_den's Avatar
Default Re: HD problem
Did you try to merge your OS partition with some other..? Probably you can try to fix the MBR using windows CD. Put in the Windows CD, press R to get the command prompt, select your HDD then type "fixmbr"
That should help you boot into windows. Else you can try some boot utility CDs or linux CD to try and fix the MBR..
prasad_den is offline
Old 10-07-2008, 12:11 AM   #3 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Post Re: HD problem
its not MBR(master boot record ) problem.when i boot from xp its just show press enter to boot cd-rom then nothing happen only black screen show
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 12-07-2008, 03:19 PM   #4 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
hey no one know is here to help me
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 12-07-2008, 05:24 PM   #5 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Choose the first xp and press F8,choose last known good configuration if that didnt work try loading safe mode to edit boot.ini.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 12-07-2008, 11:43 PM   #6 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Unhappy Re: HD problem
i tried boot from first but not working and safe mode same result any professional member plz where r u guys
Dell 15z + WD 2TB
iPhone 4 32 GB
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by chris
