Old 09-07-2008, 09:25 PM   #1 (permalink)
MAK
MAK's Avatar
Red face Problem with explorer
HI!
I got problem with 'my computer'
whenever i click on any of my partitions(C:,D:,E
they open in new window
and
I am not able to see my hidden files even if i turn it on from folder options
need help
I think its due to some virus
I m using Avast anti virus and no virus is detected
Help me plz
MAK is offline
Old 09-07-2008, 09:33 PM   #2 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Default Re: Problem with explorer
Your antivirus has removed the virus (trojan)
But registry is still infected
Use Spybot S&D or Spyware Doctor to remove registry infections
To manually remove them
See Here
Also Here
Also Here
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 10-07-2008, 10:52 PM   #3 (permalink)
MAK
MAK's Avatar
not worked .........
I tried the links which u gave
I changed checked value to1 in hidden showall registry
but it automatically becomes 0
I will try using spybot or spywaredoctor
MAK is offline
Old 10-07-2008, 11:26 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
boot in safe mode and try those methods....
ravi_9793 is offline
Serious Problem Need help (EXPLORER) max_demon Software Q&A 8 08-05-2007 11:36 PM
Problem with explorer manuajith Software Q&A 4 05-04-2007 05:25 PM
problem with explorer Samish Tutorials 2 06-11-2006 08:26 PM
problem with explorer njm Software Q&A 2 12-09-2006 01:37 PM
Explorer Problem !!! dreams Software Q&A 6 24-12-2005 07:42 AM
- by chris
