Old 09-07-2008, 08:34 PM   #1 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
Default Speed_Error
Hi all...I m facing strange problem this days, my pc (window) taking double time for every process but if i format my pc then it works fine for 1/2 days but againn something happens & all process are become very slow means taking double time.
For Exm :- 1] If i format my pc then my pc start in 15 sec but if that problem comes then my pc takes more then 30 sec to start.
2] Noramally nero takes 10 minutes to right dvd but with that problem it takes more then 20 minutes.
3] Same problem with copy/paste, defragmentation, ErrorChecking etc...
If i start any process then its not possiable to me to use pc for other things like another process, listen songs, watching movies etc... coz its slow down everything even my mouse cursor is also moving very slow plez plez plez help guys...
I format my pc 10 times now but same problem comes again & again after some time.
Now i m reaaly tired by formatting & main probleem is its not a permeny solution so plez guys help me out from this huge problem.
CHALLENGER is offline
Old 09-07-2008, 09:40 PM   #2 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Default Re: Speed_Error
Disable services like Remote Registry & Indexing service
Type services.msc in run dialog box
Then select Remote Registry double click it & then select disable
Also Disable system restore (Right Click My Comp.> System Restore)
Remove Prefetch files from X:/Windows/Prefetch folder
Unable to follow all these steps
Try Tune-Up Utilities
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 09-07-2008, 10:10 PM   #3 (permalink)
►T3CHWΦRM◄
CHALLENGER's Avatar
Thanks for ur help bro...but its not working i try what u told me to do, i off that teo servises, i delete perfetch folder but nope same problem every process takes more then double time compair to normal time. Thanks 1s again for ur reply.
- by chris
