Old 09-07-2008, 11:39 AM   #1 (permalink)
Default Plz suggest: connecting multiple machines
I have a BB connection with static IP. Is there any way by which i can connect multiple machines to it and share the netconnect ???
Please suggest guyz
RoCkSoLiD is offline
Old 09-07-2008, 11:45 AM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Plz suggest: connecting multiple machines
Get a Hub and some CAT5 ethernet cables. You will need 2 lan cards in the primary machine.
Pathik is offline
Old 09-07-2008, 12:12 PM   #3 (permalink)
Thanks@Pathik
A step-by-step guide will be very helpful
wired/wireless network, anything would do
shared fax machines shobhit_newgen QnA (read only) 1 26-05-2008 12:52 PM
Simple Machines Forum pritish_kul2 Internet & WWW 19 16-03-2007 02:37 PM
Virtual Machines starscream QnA (read only) 5 08-07-2005 10:32 PM
How To Add Multiple MX Entries And Set Multiple Preference? tuXian QnA (read only) 7 03-03-2005 06:23 PM
Suggest a Bluetooth Device for Connecting PC to Nokia 3650 quad master QnA (read only) 9 29-12-2004 01:19 AM
- by chris
