You can try installing the trial for
ESET Nod32 Antivirus v3.0.650 and directly update and scan with it. It does not require a restart of your computer after installation. But you may have to restart your comp after uninstalling your current antivirus.
Note: The latest version of ESET Nod32 Antivirus is v3.0.667. But that version is not available as a trial download. The above link is for 32bit Windows Vista/XP/2000
