Old 08-07-2008, 02:19 PM   #1 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default How to Recover data from inaccessible drive
Hi,
How to Recover data from inaccessible drive. My E: drive was working fine till yesterday. But, now when i double click my E: , it says "E: is inaccessible, do u want to format it now?"
And the main thing is that I have my precious data on that drive, so how to recover this data?
Pls help me.
Thanx.
Blogging at:
Technostarry
saqib_khan is offline
Old 08-07-2008, 02:23 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: How to Recover data from inaccessible drive
use a BartPE Live CD and boot using this it will allow u recover any data in ur HDD
even if its inaccessible in windows...
PS: the data shud be there atleast & shud not be deleted
Zangetsu is offline
Old 08-07-2008, 07:00 PM   #3 (permalink)
You can use Spinrite by Gibson. Its small & beautiful coded in assembly
http://www.grc.com/sr/spinrite.htm
Janki
janki2008 is offline
Old 08-07-2008, 07:53 PM   #4 (permalink)
Amir.php's Avatar
+1 for BartPE.
it surely recover your data.
Amir.php is offline
Old 08-07-2008, 09:26 PM   #5 (permalink)
smile's Avatar
Wink Re: How to Recover data from inaccessible drive
Is it a Hard drive or a pen drive u are talking about E drive . If it is a hard disk drive then i think it infected with virus...I suggest u to scan in safe mode and enable show hidden files and folder and go to each drive and check the autorun.inf file and delete it..If it is pen drive then Google it u will get a lots of recovery softwares
SR
smile is offline
Old 08-07-2008, 11:43 PM   #6 (permalink)
I M A *STAR*
saqib_khan's Avatar
It is a hard drive.
BTW, is there some option to recover data in BartPE CD??
I have this CD. Can ne1 explain me the process?
Blogging at:
Technostarry
Old 09-07-2008, 12:37 AM   #7 (permalink)
prasad_den's Avatar
Use a live Linux CD and recover all the data.. any distro would do the job.
prasad_den is offline
Old 09-07-2008, 02:06 AM   #8 (permalink)
Back on Earth .
hell_024's Avatar
Arrow Re: How to Recover data from inaccessible drive
Well even i had the same problem ; wen ever i used to boot into XP it used to go for a sys consistency check for the drive ; nd when XP got loaded i cudnt access the drive ; it used to giv me this dialog box "Open with " ..
this happens only wen im in XP not in Vista
However i have no idea how it got alright today; ...i was perplexed wen i cud access the drive ..
can sum1 thro some light on this?..
A student till infinity .
hell_024 is offline
Old 09-07-2008, 09:54 AM   #9 (permalink)
Fullbring
Zangetsu's Avatar
This happend due 2 virus....it created a file autorun.inf + some other .exe files in the
root directory....& i guess dat file got deleted dats y u got "open with"
Zangetsu is offline
Old 09-07-2008, 04:52 PM   #10 (permalink)
Tech'ing life seriously!!
sude's Avatar
well dear khan,
u hv been attacked by an autorun + vb script virus.
do the following
1. download n install unlocker from www.ccollomb.free.fr/unlocker
2. open MSCONFIG (by typing MSCONFIG in Run)
3. shut off all the NOT REQD progs from the STARTUP list..
4. Restart the system in SAFE MODE.
5. go to that drive. (open by alternate click on the drive and selecting OPEN)
6. select files like "autorun.inf" and "*.vbs"
alternate click on these files and click on UNLOCKER
and finally select all the files in the list which has a connection with the Above vbs or inf files........ AND CLICK DELETE...
U will get an confirmation..
thats it..
reply wid wht u did..
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 10-07-2008, 12:08 AM   #11 (permalink)
Back on Earth .
hell_024's Avatar
@karanth85 ..it still makes me wonder what made it fine ..
hell_024 is offline
Old 10-07-2008, 10:25 AM   #12 (permalink)
Fullbring
Zangetsu's Avatar
dont be surprised hell_024 there r lots of users who have faced this issue..so u r not the 1 alone....my frnd also got this issue with a "#####%#" type of string in the ryt click
of all the drives....
when we managed 2 open the drives using "explore.." we checked the autorun.inf which
was hidden & dat string was written there...
Zangetsu is offline
Old 10-07-2008, 07:31 PM   #13 (permalink)
Yoda's Avatar
use O&O Rescue Box boot CD and try recover it
Yoda is offline
Need to recover data from a corrupt drive karan129 Hardware Q&A 4 04-07-2008 10:10 PM
folder on usb drive inaccessible on changing computer neilsatyam Software Q&A 3 14-12-2007 02:06 PM
Recover Data from NTFS Drive redhat QnA (read only) 1 08-12-2007 09:48 AM
What Softwares/techniques data recovery professional use to recover data from HDD ? CadCrazy Software Q&A 1 10-08-2007 10:01 AM
how to recover my old data?????? Sankalp QnA (read only) 3 15-09-2005 10:10 PM
- by chris
