Old 03-07-2008, 05:34 PM   #1 (permalink)
Tech'ing life seriously!!
sude's Avatar
Exclamation Required a Software to create a database without using SQL etc.. PLZ HELP.
dear forum users,
i am searching for a software which actually manages to create the database/s which do not use SQL etc....
actually one of my friend's father will be using such a database for maintaining his job details.. his father's job is to maintain his client's databse.. his father is an financial advisor and manager...
2-3 years back on the digit CD's a software came which manages to create database through wizard mode... no codes ... nothing.. i dont remember the name of the software but i remember that i used that software for keeping the details of the software installed on my system.. now i dnt use that..
can anyone remember the software or can anyone recommend any such software (free / paid No matter) .. plz reply..
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 04-07-2008, 03:06 AM   #2 (permalink)
18 Till I Die............
Default Re: Required a Software to create a database without using SQL etc.. PLZ HELP.
Why not MS Office or Open Office?
http://www.bash.org/?258908
mehulved is offline
Old 04-07-2008, 04:25 AM   #3 (permalink)
MMO Addict
amitava82's Avatar
Microsoft Access
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 04-07-2008, 01:46 PM   #4 (permalink)
sude's Avatar
dear forum users,
-SUDE
well amitava and mehulved.../
i think u are not getting me..
the soft i am talking about doesn't need any SQL, ACCESS or any other codes... it works independantly.. and creates the backend and frontend part through the wizard... and at the end the user requires to enter data directly without bothering about any code/s...
such a software was there in digit CD's 2-3 years back.. if anyone remember the name of the soft please reply.. or any similar soft plz reply with the name.. whether free or paid no matter.. my friend is ready to buy..
waiting for a reply..
-SUDE
sude is offline
want to create a database for my excel data? raja2281 Programming 2 16-06-2008 02:26 AM
Database 2 create record ! ! ! ax3 Programming 5 14-05-2008 04:58 PM
Need to create software dashang Programming 15 17-05-2007 08:33 PM
Fox Pro DataBase Software / Document/PDF muralikrishnan Tutorials 1 17-11-2006 12:00 PM
- by chris
