Old 03-07-2008, 11:52 AM   #1 (permalink)
9437077259
go4saket's Avatar
Default Problem with Kaspersky Internet Security 7
Hi Guys!
I had been using KIS 7.0.1.325 since the last six months or so and never faced a problem. Since some days I am facing two problems:
1. Everytime I start Inter Explorer 7, it gives me a warning saying "Executable file has changed" and do I want to allow it or block it. Although it doesnt detect any virus in it, it keeps giving this error. Till the time I dont select Allow, it doesnt allow me to work in it. Why is this happening?
2. Everytime I plug in my Flash drive, it says that "autorun.inf" contains a virus and needs to be deleted. Even if I select delete, the file is automatically re-created and the same thing happens again and again and again. Apart from this it does the same thing with a hidden file called "DriveProtect.exe". Amazingly, this happens with any Flash drive that I plug in, even a brand new one and even a newly formatted one. I tried the same drive in my laptop which has Avast and there was no problem there. Then I tried the same drive in another PC with the same version of KIS and found the same problem there. Is this some kind of a bug. This started happening since yesterday and was never seen before.
Please help.
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 06-07-2008, 02:17 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Problem with Kaspersky Internet Security 7
ur computer is infected, do a full system scan
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 06-07-2008, 02:49 PM   #3 (permalink)
Rubik's Uncle!!
Charan's Avatar
@go4saket: upgrade to KIS 2009 .. if you have a valid licence then you can migrate to KIS 2009 with out buying new licence.
Charan is offline
Old 06-07-2008, 07:39 PM   #4 (permalink)
Amir.php's Avatar
1. for this do it:
Exit Internet Explorer.
Delete iExplore.exe from the Firewall/AntiHacker rules.
Click OK.
Go back to the page where the Firewall/AntiHacker rules are, click Add... (click "browse" and find iExplore.exe or click "applications" and find iExplore.exe).
Click Template>InternetExplorer.
Click OK>OK
Open Internet Explorer.
2. seems your system also infected by malwares.
check more here:
http://spywarefiles.prevx.com/RRICDG...OTECT.EXE.html
Amir.php is offline
can i use kaspersky internet security together with nod32??? tango_cash Software Q&A 8 15-05-2008 12:21 PM
Download Kaspersky Anti-Virus 7.0 and Kaspersky Internet Security 7.0 for Win Vista Third Eye Technology News 31 22-10-2007 12:18 PM
Kaspersky Internet security suite blademast3r Software Q&A 13 06-10-2006 12:09 AM
Kaspersky AntiVirus/Internet Security v6.0 Goes Final!!! kalpik Software Q&A 19 10-04-2006 12:20 PM
Kaspersky Internet Security! Biplav Internet & WWW 1 02-06-2005 08:24 PM
- by chris
