Am not sure how chotocheeta says wifi is safe while he continues to say its the same as connecting to the net - am sure connecting to the net isnt safe with out any security software protection !!!
under NTFS partition unless you manually edit settings to allow any one part from Admin user to have read - write access there are noways unwanted people to have data access in your system...
Unless you manually authenticate any RDC software to have control of you PC there is no way a 3rd party can access your desktop session...
the only antivirus softwares that offers wifi protection is trend micro - so i guess you need to use TIS to protect you laptop -
What you are talking about is Malware protection, which is needed even if you have wifi or not...
Connecting to the Net, means Network, that network may be internet / extranet / VPN / Ethernet / WAN or any type... If you are in a trusted network, you do not need any security where as if you are not sure about the network then you need security
To browser known web sites, to open only know email and using a good email service having its own AVS, one may not need a security suit in his desktop
