Old 30-06-2008, 10:06 PM   #1 (permalink)
smile's Avatar
Question Having a problem..plzz help
Hi.........Everyone
My friend send me a game in excel ... it was not opening , i thought its need a flash player to open so i installed ,but unfortunately it not opening . I have Vista installed and Microsoft Office 2003 but the same mail i forwarded to one of my my friend and their its working fine he too has vista and office 2003 installed..So what is the problem in my system?
SR
smile is offline
Old 30-06-2008, 10:11 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Having a problem..plzz help
How can a game be in Excel ?? unless its some thing reading game or such :lol
: and why would an excel file need flash ??
may be they have some update which your system is missing which is required to run the game, like SP3 or Office Compatibility Pack SP1 or such !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 01-07-2008, 12:01 AM   #3 (permalink)
smile's Avatar
Smile Re: Having a problem..plzz help
yes chota cheeta the game is in excel ...its called apple shooter ....i wil send u a mail if u like me to send ...can i have ur mail id
SR
smile is offline
Old 01-07-2008, 12:03 AM   #4 (permalink)
gopz's Avatar
There are several games in Excel and a few in Word too. You can Google to find out more and update your knowledge, instead of laughing and mocking at someone who has come here to ask for help!
gopz is offline
Old 01-07-2008, 06:26 AM   #5 (permalink)
Amir.php's Avatar
What error occures when you try to run the game?
Amir.php is offline
Old 01-07-2008, 10:36 AM   #6 (permalink)
smile's Avatar
Angry Re: Having a problem..plzz help
Iam not getting any error .....just its not loading or starting the game
SR
smile is offline
Old 01-07-2008, 12:24 PM   #7 (permalink)
Amir.php's Avatar
Right click game.exe
select the properties> compatibility tab> check "Run this program as admin"
now try run.
also can try to campatibility mode of xp(sp2)
Amir.php is offline
Old 01-07-2008, 07:34 PM   #8 (permalink)
dhanusaud's Avatar
Let me know the ver of office suite u r using.
@Choto Cheeta
Go to www.gamesexcel.com for info
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 01-07-2008, 09:02 PM   #9 (permalink)
smile's Avatar
Red face Re: Having a problem..plzz help
Office 2003 am using.....what is office suite
SR
smile is offline
Old 02-07-2008, 10:43 AM   #10 (permalink)
Amir.php's Avatar
Arrow Re: Having a problem..plzz help
really dont no?
Collection of office softwares. such as word, excel, access, powerpoint, publisher etc called office suite.
try what i was say?
Amir.php is offline
Old 02-07-2008, 03:53 PM   #11 (permalink)
smile's Avatar
ok
SR
smile is offline
Old 02-07-2008, 04:23 PM   #12 (permalink)
Tired of being sorry!
quad_master's Avatar
Question Re: Having a problem..plzz help
tell me 1 thing...when u open the game's excel file then MS Office pop-up a screen with 'enable/disable macro' option???
There are 10 types of people in this world, those who understand binary and those who do not.
quad_master is offline
Old 02-07-2008, 05:35 PM   #13 (permalink)
dhanusaud's Avatar
Lemme know if you have SWF player installed in your system or drag the game in Inter Explorer.
It sud work fine now.
Old 03-07-2008, 12:27 AM   #14 (permalink)
smile's Avatar
I think game requires flash player , but i have already installed flash player .
SR
smile is offline
Old 03-07-2008, 04:48 PM   #15 (permalink)
flw dis-
open that excel > tools > macro > security > set the security level to 'medium' > save the changes
reopen the excel file...'enable the macro' option...bingo!!
Old 04-07-2008, 01:10 AM   #16 (permalink)
smile's Avatar
@quad master : am not getting any pop up to enable macro when i open the excel
SR
smile is offline
Old 04-07-2008, 02:00 PM   #17 (permalink)
Exclamation Re: Having a problem..plzz help
hmm...u sud get dat kinda pop-up
btw if the file come in zip then u hav to extract it...then flw above steps
actually i have dat game...i faced da same problem...nd i sort it by this process
if evrything fails...dwnld again nd try afresh...
Old 04-07-2008, 04:36 PM   #18 (permalink)
Amir.php's Avatar
Last guess:
seems you are trying to run game directly from zip folder.
first extract into a folder, then run it.
Amir.php is offline
Old 04-07-2008, 05:55 PM   #19 (permalink)
smile's Avatar
Not a zip folder .... i got a mail and i saved it and its an excel file.
SR
smile is offline
Old 04-07-2008, 06:01 PM   #20 (permalink)
Amir.php's Avatar
What is extension?
Amir.php is offline
Old 04-07-2008, 10:04 PM   #21 (permalink)
smile's Avatar
Talking Re: Having a problem..plzz help
.xls
SR
smile is offline
Old 05-07-2008, 09:03 AM   #22 (permalink)
Amir.php's Avatar
now, you know why this game not run?
your friend send you .xls file without packing it in zip.
it is not an ordinary excel file.
it contains intractive contents.
Sending directly these types of file result in loss of some important information.
say to friend , send it in zip.
Amir.php is offline
Old 05-07-2008, 09:26 AM   #23 (permalink)
epic analysis lolz
Faun is online now
Old 05-07-2008, 09:36 AM   #24 (permalink)
Amir.php's Avatar
Originally Posted by T159 View Post
epic analysis lolz
What your means?
say clear you lol.
Amir.php is offline
Old 05-07-2008, 09:44 AM   #25 (permalink)
What your means?
say clear you lol.
posted by original poster:
"...but the same mail i forwarded to one of my my friend and their its working fine..."
PS: people there is a difference b/w their and there, sense and sence (doesn't make any sense though)...lolz
Faun is online now
Old 05-07-2008, 09:53 AM   #26 (permalink)
Amir.php's Avatar
ok, i am going.
it is your time to solve it.
by.
Amir.php is offline
Old 05-07-2008, 10:03 AM   #27 (permalink)
^^don't go
solve his problem, i appreciate your effort
Faun is online now
Old 05-07-2008, 01:02 PM   #28 (permalink)
smile's Avatar
Hm........ i dont think he needs to send me that file in a zip folder because same file or mail can be opened and the game is playing fine in other systems
SR
smile is offline
Old 05-07-2008, 06:09 PM   #29 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
If its a game base don Macros then you need to change the macro Security to a lower level. but i see that was already suggested. You can check again by setting ti to low for this file and try again.
Also try installing a shockwave player. you might want to get the URL for the flash site he got the Flash game from just in case so you can access it.
FilledVoid is offline
Old 05-07-2008, 07:57 PM   #30 (permalink)
smile's Avatar
thanks a lot for advice.....will surely try and let u know .. but tel me how to change Macros security
SR
smile is offline
Plzz Help smile Software Q&A 2 13-11-2007 01:05 AM
graphics card problem ?????..plzz help... anilthomas26 Graphic cards 2 11-01-2007 12:32 AM
INternet explorer problem....plzz help Abhishek Dwivedi Software Q&A 5 22-12-2006 06:20 PM
Plzz help me hl2.. medigit Gamerz 6 24-03-2005 12:54 AM
PROBLEM WITH REALPLAYER..CAN ANY ONE HELP ME PLZZ ..!! wizard_with_a_wand Software Q&A 4 09-01-2005 06:12 PM
- by chris
