Old 29-06-2008, 07:04 PM   #1 (permalink)
smile's Avatar
Question Help Plzz
Iam not able to get the volume icon and network icon on my system tray .Iam uing Vista.Plzz Can anyone help me. I even check their properties but no use
SR
smile is offline
Old 29-06-2008, 08:28 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Help Plzz
Control panel->sounds and audio properties.
there's a box called Place Volume Icon in Taskbar. Make sure its checked.
dheeraj_kumar is offline
Old 29-06-2008, 08:46 PM   #3 (permalink)
smile's Avatar
Unhappy Re: Help Plzz
am using vista ..............no such option is there
SR
smile is offline
Old 29-06-2008, 09:49 PM   #4 (permalink)
dhanusaud's Avatar
vista user here!
right click on start orb
select properties & go to notification area tab
and select the system icon you want to display.
well, smile I am noticing that u r getting lots of system probs now-a-days.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 30-06-2008, 01:27 AM   #5 (permalink)
smile's Avatar
Talking Re: Help Plzz
Systems are meant to get repaired............is it ???
SR
smile is offline
Old 30-06-2008, 06:29 AM   #6 (permalink)
dhanusaud's Avatar
may be, but not all the times
Old 30-06-2008, 07:22 AM   #7 (permalink)
In a New flavour
Most Wanted's Avatar
Yes, it is the time to repair.
want to know how?
Life Grows Best, When Deciplined
Most Wanted is offline
Old 30-06-2008, 09:28 AM   #8 (permalink)
dhanusaud's Avatar
want to know how?
दिमागका भरता मत बनाओ डियर
Old 30-06-2008, 09:35 AM   #9 (permalink)
hrushij's Avatar
I think You have to install drivers from your motherboard CD.
HHJobanputra
hrushij is offline
Old 30-06-2008, 09:38 AM   #10 (permalink)
In a New flavour
Oh, you are greate.
i like hindi.
agar bhurta ban gaya ho to bata dena, kab bula rahe ho?
Old 30-06-2008, 09:42 AM   #11 (permalink)
dhanusaud's Avatar
अरे यार, तुम्हरा जवाफ है या प्रश्न?
Old 30-06-2008, 10:05 AM   #12 (permalink)
In a New flavour
Are dhanu bhai mera matlab hai ki agar dimag ka bhurta bana lena to invite karna na bhoolna diner pe.
Help Help Plzz Help? smile Software Q&A 10 25-06-2008 11:04 PM
Plzz Help smile Software Q&A 2 13-11-2007 01:05 AM
Plzz help me !!! jasperjunnu Hardware Q&A 1 19-03-2007 12:44 AM
plzz tell me, how can...... sandeep bhatia QnA (read only) 2 30-11-2006 11:22 PM
Plzz help me hl2.. medigit Gamerz 6 24-03-2005 12:54 AM
- by chris
