Old 28-06-2008, 10:49 PM   #1 (permalink)
Smile XP Automated Installation using nlite
I want to use nlite for a sp3 slipstreamed,cutdown and automated installation of xp.I want manual contol over choosing whether to repair or not,making partitions and formatting using fat or ntfs.But after the first the reboot i want to automate everything,i.e,product key regional settings etc.I also want automation after the installation,i.e,turning on automatic updates etc.Also,while making the xp slimmer,I want it to be able to boot into safe mode.What options should I use?
ashiksn1 is offline
Old 29-06-2008, 09:43 AM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: XP Automated Installation using nlite
Check out MSFN forums... they are the best source for automating xp install. Everything you said above can be done by nLite.
dheeraj_kumar is offline
Old 29-06-2008, 10:41 AM   #3 (permalink)
Amir.php's Avatar
Arrow Re: XP Automated Installation using nlite
Hey, You not need to go any where other.
Just follow the link and Read a Great tutorial by Our forums Most Respected Person Vishal Gupta.
http://www.askvg.com/the-best-and-th...dows-xp-setup/
Amir.php is offline
Old 29-06-2008, 10:08 PM   #4 (permalink)
dhanusaud's Avatar
great tutorial from VG.
Thumbs up buddy.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
How 2 use nLite???????????? Naveed Software Q&A 1 26-01-2007 03:08 AM
Automated software??????? Debu_013 Software Q&A 2 13-05-2006 12:28 PM
UWin Installer - Make Your Windows Installation/UPGradation AUTOMATED utsavhanda Software Q&A 1 26-04-2006 02:35 PM
Automated Rebooting grinning_devil Software Q&A 8 05-04-2006 08:35 PM
Automated installation of Win 98... linardni Software Q&A 2 31-03-2006 12:21 AM
- by chris
