Old 27-06-2008, 09:38 PM   #1 (permalink)
bonny72's Avatar
Default need help to use my DVD player in to car
Dear all
I like to use my passion home DVD player ( USB and divX/Xvid supported) in to my car. it need 12v and 5v DC power. I already removed power supply 220W from player. now i need something which can give me 12v and 5v power.
12v i can get from my car but for 5v what should i do. if this will work then i can make car DVD player in less then 2000/- with USB and Divx/xvid.
in car shop car dvd player cost 6000 to 12000 without usb.
please help
bonny72 is offline
Old 27-06-2008, 10:00 PM   #2 (permalink)
din
Tribal Boy
din's Avatar
Default Re: need help to use my DVD player in to car
There is a (Chinese of course) device which convert car voltage to different (lower) voltages. I used it long back. Will try to find it and will post a photo.
Edit
OK, it is something like this
Link Here
din is offline
Old 28-06-2008, 12:24 PM   #3 (permalink)
bonny72's Avatar
Thumbs up Re: need help to use my DVD player in to car
thnaks din
now i have to find this type of thing in market
bonny72 is offline
Old 28-06-2008, 12:58 PM   #4 (permalink)
din
Tribal Boy
din's Avatar
Check with the electronic shops, you will sure get it.
din is offline
M69885.Moser player dvd player?Where to get it??? harpoon Software Q&A 1 05-06-2008 01:44 PM
converting Sony vcd/cd player To Dvd/mp3 player aXisxX Software Q&A 3 04-02-2008 08:50 PM
cassette player or CD player for car? nix Software Q&A 16 16-11-2007 09:50 PM
Can I watch all channels? <<media player or real player>> digidream Software Q&A 2 06-09-2005 04:42 PM
New 30 GIGS PDA + MP3 player + Video player Tuffleo Buying Advice 1 09-07-2005 03:51 PM
- by chris
