Old 27-06-2008, 02:03 PM   #1 (permalink)
smile's Avatar
Question Help me....Hard disk problem
My friend pc is not booting , i checked it a msg is displaying on bootup IDE 0 slave S.M.A.R.T has been disabled...but the problem is i get windows xp screen and again it restarts . I checked my hardisk its detected in BIOS , i changed the SATA cable , even connected as master and check but its shows IDE 0 SLAVE has been disable.Can anyone help me plzz
SR
smile is offline
Old 27-06-2008, 08:11 PM   #2 (permalink)
Amir.php's Avatar
Default Re: Help me....Hard disk problem
You must enable SMART Feature in BIOS.
You can find it under the primary/secondary ide device.
Amir.php is offline
Hard Disk problem kevin_476 Hardware Q&A 4 24-01-2007 01:58 AM
hard disk problem geforce4 Hardware Q&A 1 06-11-2005 01:02 PM
PROBLEM WITH HARD DISK coolrupesh Software Q&A 1 01-11-2005 12:40 PM
Problem with Second hard disk. abhijitroy QnA (read only) 2 25-05-2005 05:55 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by chris
