Old 25-06-2008, 09:42 PM   #1 (permalink)
Default In vista Am not able to extract any file from winrar directly?..Plz help and granting
If i try to extract a winrar file by just right cliking and extract to (name of the folder) [Which comes in the drop down arrow]----It doesnt work no folder is created or nothing is done...Rather i have to open winrar -allow permissions and go to extract to -- specify folder than extract--It looks like a long process?...And also am not able to compress any folder to rar format by rightclikin and add to archive --It doesnt give any error messages or nothing--It just ignores anything---I think it is bec of the permission problems which i have to allow everytime...Is der anyway to remove the permission problems automatically allow so tat i dont need to grant wen i install something or extracting?
roonie is offline
Old 25-06-2008, 10:52 PM   #2 (permalink)
Web developer
narangz's Avatar
Default Re: In vista Am not able to extract any file from winrar directly?..Plz help and gran
Download the latest version & run the setup with administrator priviliges.
It works fine on my system, so there's no incompatibility problem.
narangz is offline
Old 26-06-2008, 10:55 AM   #3 (permalink)
Amir.php's Avatar
Arrow Re: In vista Am not able to extract any file from winrar directly?..Plz help and gran
Boot into "Safe Mode with networking" from the boot menu.
Open a command window (START->RUN->CMD.exe). At the command prompt type the following "net user administrator /active".
reboot your system.
That’s it. Log out and log back in as administrator.
This will allowed you An administrator icon at startup. Log into this account and after uninstall and again install winrar.
Now it should work fine.
Advantage: You not need to choose again and again admin previlages.
Disadvantage: Security issues
Amir.php is offline
Old 26-06-2008, 11:03 AM   #4 (permalink)
Web developer
narangz's Avatar
^^ No need for that. Just install it using admin privileges by right clicking & selecting run as admin. It runs fine. No problems at all.
narangz is offline
Old 26-06-2008, 11:10 AM   #5 (permalink)
Amir.php's Avatar
Just a trick Only yar
Use or not use it your desire.
Amir.php is offline
Old 26-06-2008, 11:28 AM   #6 (permalink)
dhanusaud's Avatar
try winzip..it will work fine. anyway reinstalling winrar may solve your problem.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 26-06-2008, 01:52 PM   #7 (permalink)
Web developer
narangz's Avatar
Ok. It can be useful in many scenarios but I shall never recommend it due to security issues.
narangz is offline
Old 27-06-2008, 05:02 PM   #8 (permalink)
Is der anyway to run as a administrator ful time?...
roonie is offline
Old 27-06-2008, 05:08 PM   #9 (permalink)
Web developer
narangz's Avatar
Right click the winrar executable- click compatibility tab & check 'run this program as an admin' under privileges.
narangz is offline
Old 27-06-2008, 05:21 PM   #10 (permalink)
Tried it now ..Not working..!..any other way
roonie is offline
Old 27-06-2008, 08:19 PM   #11 (permalink)
Amir.php's Avatar
Now try my method.
Amir.php is offline
Old 27-06-2008, 10:56 PM   #12 (permalink)
Now try my method.
Ya Amir it worked..Thanks...Now how to deactivate the admin at the user log on and also is der any way to make the main user which am using with admin privilages?>
roonie is offline
Old 28-06-2008, 01:19 PM   #13 (permalink)
Amir.php's Avatar
Dont deactivate admin account. it help you in future.
just protect it with a strong password from control panel.
i always log in vista with admin.
install better antivirus like avast. it automatically update itself everyday in just a minute.
if you use vista carefully, you not need to afread with any security issue.
Amir.php is offline
Old 29-06-2008, 02:50 PM   #14 (permalink)
Okay but...Wen i start the com can i make it like automatically log in into my main user rather than it asks me which user to log in..??
roonie is offline
Old 29-06-2008, 07:10 PM   #15 (permalink)
Amir.php's Avatar
Follow these steps:
1. click on vista start button.
2. type "netplwiz" without quote in the search box and press enter.
3. if user access control window pop ups for permission, click continue.
4. at the user account control window, uncheck and clear the "user must enter a username and password to use this computer" option and click ok.
5. in the automatically logon window, input the useid and password the user account that you want to vista to automatically login when start up and click ok.
6. restart for effect.
Amir.php is offline
Old 29-06-2008, 08:34 PM   #16 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Forget winrar use 7zip its freeware and better than winrar . . .
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 29-06-2008, 09:45 PM   #17 (permalink)
Amir.php's Avatar
Problem is other.
dont give answer without understanding it, ok.
Amir.php is offline
How to extract the .SFV file====HELP!!! prateek_san QnA (read only) 6 15-04-2007 04:45 PM
how to extract a partially downloaded .rar file shashank_digitreader Software Q&A 6 04-11-2006 08:24 PM
how to extract and merge audio into an AVI file nd4spd Software Q&A 7 18-08-2006 12:57 PM
boot directly from any iso file by first booting from dvd arunks Software Q&A 2 22-07-2006 11:14 PM
extract a part of a vob file cybermanas QnA (read only) 1 05-10-2005 09:02 PM
- by chris
