Old 23-06-2008, 07:48 PM   #1 (permalink)
Default Internet Explorer Problems
Hey, despite being proved that firefox and opera are better, my father refuses to use any browser other than the standard internet explorer that comes with xp.
Now-a-days when he closes internet explorer close to 48 windows of IE seem to open. I checked with norton and i don't seem to have a virus. Why exactly does this happen? And i think i might have to uninstall IE and install 2007 or something. My question is how exactly do i uninstall IE? it doesn't show up in my Add-remove programs list, and if i remember correctly there's a registry hack involved. Can someone tell me what i have to do?
Any help would be appreciated.
Our deepest fear is not that we are inadequate Our deepest fear is that we are powerful beyond measure
karmanya is offline
Old 23-06-2008, 07:59 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: Internet Explorer Problems
You cannot un-install IE, you can upgrade it.
Follow this link, choose your OS & download: http://www.microsoft.com/windows/dow.../getitnow.mspx
http://beingmanan.com
iMav is offline
Old 23-06-2008, 09:56 PM   #3 (permalink)
* Teh Flirt King *
Quiz_Master's Avatar
Looks like your PC is infected with a Adware which causes Pop-Up windows in IE... (IE is prone to Adwares and Spywares)...
Since you can't tell your dad to change browser...I suggest you install Some adware and Spyware Cleaners...
Use these :
1.) Adware
2.) SpyBot Search And Detroy
Unistalling IE:
IE can removed.
Go to add romove programs. The 3rd Option in side list is "Add Remove Windows Components".. Through it you can remove IE. Its not recommended though as other programs depend on it.
Quiz_Master is offline
Old 23-06-2008, 10:50 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
IE is integrated into the OS. Cant be removed. If you have upgraded from IE6 to IE7, only then you may see and option to remove IE (ie IE7). Looks like an adware infection to me. The fault is not of IE if you suddenly have multiple IE's opening up on their own. Scan in safe mode with a good anti virus and anti spyware. Wouldnt be surprised if your Norton has missed infections. Try Avast/AVG/Kaspersky/Nod32 and AdAware/Spybot/a-squared instead. Get your HJT log analysed at www.hijackthis.de to be sure.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 23-06-2008, 11:34 PM   #5 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Just a trick, get some IE skin for firefox and see if you can made your dad use it
गीक होना माँगता
victor_rambo is offline
Old 24-06-2008, 03:30 AM   #6 (permalink)
@rohan, have you heard of the saying "a little bit of knowledge..."? Its the same way with my dad, he knows just enough to be able to distinguish firefox from IE, but enough to recognise that windows products may not necessarily be better as compared to certain free ones. He doesn't even let me run linux live cd's, forget about dual booting.
Ill try to scan the system, thanks for your help guys
karmanya is offline
Old 24-06-2008, 10:34 AM   #7 (permalink)
Amir.php's Avatar
Thumbs up Re: Internet Explorer Problems
We can Uninstall ie if your os is XP.
Control Panel> Add Remove Programs> In the Left "Add/Remove windows component"> Uncheck internet explorer from the component List.
Amir.php is offline
Old 25-06-2008, 06:36 PM   #8 (permalink)
g_goyal2000's Avatar
It doesn't uninstall it. It just removes it's shortcut from Desktop, Start Menu, Quick Launch toolbar.
Confirm u'r facts before u post a reply/solution.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
g_goyal2000 is offline
Old 25-06-2008, 06:50 PM   #9 (permalink)
iMav's Avatar
No you can't un-install it yaar.
iMav is offline
Old 26-06-2008, 10:30 AM   #10 (permalink)
Amir.php's Avatar
Exclamation Re: Internet Explorer Problems
Sorry iMav and g_goyal2000 really i was wrong here.
Mai samjha
it will uninstall internet explrer. But really ie is now available in ProgramFiles folder.
Actually ie is an essential part of windows. we can not Uninstall it.
Thanks for clear my doubts here.
Amir.php is offline
Explorer.exe encountering problems kanu2k7 Software Q&A 5 15-10-2008 07:43 PM
Odd problems with regard to Win XP.. explorer issues..!! prasad_den Software Q&A 3 05-04-2008 12:19 AM
Post ur mobile internet queries, problems n problems here sourishzzz1234 Buying Advice 2 19-01-2008 07:34 PM
internet explorer problems rup Software Q&A 8 16-06-2007 09:18 PM
2 Internet explorer 6.0 problems AMITAGARWAL02 Software Q&A 8 08-03-2005 02:16 AM
- by chris
